NetGear 5-port Gigabit Ethernet Switch
Key features
  • Auto-MDI/MDIX eliminates the need for crossover cables
  • LED indicators for ease of use
  • Energy-efficient technology for power savings
  • Fan-less design for quiet operation
  • Auto-negotiation for automatic connection at the highest common speed between switch and an end device
  • Non-blocking switching architecture for maximum throughput at wire speed
Product codes
These NETGEAR home Ethernet switches provide an easy, reliable, and affordable way to expand your network connections in homes and small offices.
High-performance metal case provides easy, reliable and affordable Gigabit Ethernet connection for your home network. Features include auto-MDI/MDIX (eliminating the need for crossover cables) and LED indicators for ease of use. Energy-efficient technology provides power savings.
Product Description NETGEAR GS305 - Essentials Edition - switch - 5 ports - unmanaged
Device Type Switch - 5 ports - unmanaged
Subtype Gigabit Ethernet
Ports 5 x 10/100/1000
Performance Bandwidth: 10 Gbps
MAC Address Table Size 2K entries
Jumbo Frame Support 9216 bytes
Features Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), fanless, Energy Efficient Ethernet, security lock slot (cable lock sold separately), metal housing
Compliant Standards IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3az
Power AC 120/230 V (50/60 Hz)
Dimensions (WxDxH) 10.2 cm x 9.4 cm x 2.6 cm
Weight 240 g
Localisation United Kingdom
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
