NETGEAR 550W 100-240VAC Power Supply Unit
£314.10
Delivery:
Standard: 1-3 working days
Key features
  • Additional PSU for M4300-28G-PoE+ (GSM4328PA) and M4300-52G-PoE+ (GSM4352PA)
  • C14 connector
  • Capacity: 110V-240V AC power input
  • Up to 575W output power at 110/220V AC
Product codes
NETGEAR ProSAFE Modular Power Supply Unit 550W AC (APS550W) is compatible with select Managed Switches such as M4300-28G-PoE+ (GSM4328PA) and M4300-52G-PoE+ (GSM4352PA). These M4300 series switches come with one PSU pre-installed. Another APS550W in second PSU bay can be combined for 1+1 power redundancy or 1+1 power expansion.
NETGEAR APS550W - power supply - redundant - 550 Watt
Power supply - redundant - internal
Europe, Americas
Input Voltage
AC 110-240 V
Power Capacity
550 Watt
Input Connectors
Power IEC 60320 C14
5 years warranty
NETGEAR M4300-28G-PoE+, M4300-52G-PoE+
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NETGEAR 550W 100-240VA...
£314.10
