NETGEAR Nighthawk AC2300 Smart Wi-Fi Router was built to handle all your high-bandwidth online activities with features that will keep you connected at top speeds. With the powerful 1GHz dual-core processor and Dynamic QoS, Nighthawk can prioritize bandwidth to your game so other devices on the network don't slow down your connection. Enjoy uninterrupted video streaming with limited buffering for streaming applications like YouTube, Netflix, and others. And with features like high performance external antennas, and Beamforming+, you can enhance your mobile speeds by up to 100%, so you can roam freely throughout your home without fear of slow or dropped connections.
Product Description | NETGEAR Nighthawk PR7000 - wireless router - 802.11a/b/g/n/ac - desktop | Device Type | Wireless router - 4-port switch (integrated) | Enclosure Type | Desktop | WAN Ports Qty | 1 | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Frequency Band | 2.4 GHz / 5 GHz | Data Transfer Rate | 1625 Mbps | Features | NAT support, VPN support, Stateful Packet Inspection (SPI), DoS attack prevention, IPv6 support, Quality of Service (QoS), FTP server, ReadySHARE, 3T3R MIMO technology, Beamforming+, MU-MIMO technology, Smart Connect, ReadyCLOUD | Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, DLNA CERTIFIED, IEEE 802.11ac | Dimensions (WxDxH) | 28.5 cm x 18.45 cm x 5 cm | Weight | 750 g | System Requirements | UNIX, Apple MacOS, Linux, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 | Localisation | United Kingdom |
General | |
Connectivity Technology | Wireless, wired |
Encryption Algorithm | WPA, WPA2, WPA-PSK, WPA2-PSK |
Processor | 1 GHz |
RAM | 256 MB |
Flash Memory | 128 MB |
Line Properties | |
Line Coding Format | 1024 QAM |
Expansion / Connectivity | |
Interfaces | LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x 9 pin USB Type A , USB 2.0: 1 x 4 pin USB Type A , Antenna: 3 x |
Aerial | |
Aerial | External detachable |
Antenna Qty | 3 |
Power | |
Power Device | External power adapter |
Miscellaneous | |
Cables Included | 1 x network cable |
Software / System Requirements | |
OS Required | UNIX, Apple MacOS, Linux, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 |
Dimensions & Weight | |
Width | 28.5 cm |
Depth | 18.45 cm |
Height | 5 cm |
Weight | 750 g |
