NETGEAR 8-Port 10/100/1000 Mbps Switch
£33.82
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Express: Delivered on Tuesday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Connects up to 10x faster than Fast Ethernet for maximum performance
  • Simple to combine Fast Ethernet and Gigabit devices in your network
  • Fanless design for quiet operation
  • Plug-and-play installation delivers ease of use
  • ProSafe 8-port Gigabit Desktop Switch connects your network with the dual advantages of performance and convenience
  • Fast, auto-switching Ethernet connection integrates 10, 100, and 1000 Mbps devices into your network
  • Dual color LEDs make it easy to monitor link, speed, and activity
  • AutoUplink technology automatically adjusts for two common types of cables
  • Compact metal case for desk or wall mounting
  • With plug-and-play technology, simply plug it in and it works
Product codes
Now you can have a powerful, high-speed network on a small scale. NETGEAR's GS108 Gigabit Ethernet Switch lets you build a system that provides a full, dedicated 1000, 100, or 10 Mbps connection so you can move very large files across your network instantly. The GS108 also lets you painlessly integrate 10, 100, and 1000 Mbps devices. This potent switch is packed with ease-of-use features to simplify your workday experience. Its compact design fits neatly into small workspaces and, since it's self-cooling without a fan, it runs silently and unobtrusively.
NETGEAR's GS108 Gigabit Ethernet Switch moves huge files fast! It features a high-speed, auto-switching 10/100/1000 Mbps Ethernet connection. And because Copper Gigabit Ethernet is a full duplex standard, you can get up to 2000 Mbps on each port.
NETGEAR's GS108 Gigabit Ethernet Switch integrates 10, 100, and 1000 Mbps devices on the same network. Every port automatically senses the right speed and full/half duplex mode, while Auto Uplink technology automatically adjusts for straight-through or crossover cables.
LEDs embedded in each of the 8 RJ-45 jacks make for easy monitoring. Space-saving dimensions are ideal for desktop or wall mounting in home and small office environments. And it runs quietly, self-cooling without an internal fan.
NETGEAR ProSafe GS108 8-port Gigabit Desktop Switch 10/100/1000 Mbps - switch - 8 ports - desktop
Switch - 8 ports
Enclosure Type
Desktop
Ports
8 x 10/100/1000
MAC Address Table Size
8K entries
Full duplex capability, auto-sensing per device, auto-uplink (auto MDI/MDI-X)
IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab
28.7 cm x 10 cm x 2.5 cm
0.9 kg
Apple MacOS, Novell NetWare, Microsoft Windows
NETGEAR lifetime warranty
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NETGEAR 8-Port 10/100/...
£33.82
