We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Now you can have a powerful, high-speed network on a small scale. NETGEAR's GS108 Gigabit Ethernet Switch lets you build a system that provides a full, dedicated 1000, 100, or 10 Mbps connection so you can move very large files across your network instantly. The GS108 also lets you painlessly integrate 10, 100, and 1000 Mbps devices. This potent switch is packed with ease-of-use features to simplify your workday experience. Its compact design fits neatly into small workspaces and, since it's self-cooling without a fan, it runs silently and unobtrusively.
NETGEAR's GS108 Gigabit Ethernet Switch moves huge files fast! It features a high-speed, auto-switching 10/100/1000 Mbps Ethernet connection. And because Copper Gigabit Ethernet is a full duplex standard, you can get up to 2000 Mbps on each port.
NETGEAR's GS108 Gigabit Ethernet Switch integrates 10, 100, and 1000 Mbps devices on the same network. Every port automatically senses the right speed and full/half duplex mode, while Auto Uplink technology automatically adjusts for straight-through or crossover cables.
LEDs embedded in each of the 8 RJ-45 jacks make for easy monitoring. Space-saving dimensions are ideal for desktop or wall mounting in home and small office environments. And it runs quietly, self-cooling without an internal fan.
Product Description | NETGEAR ProSafe GS108 8-port Gigabit Desktop Switch 10/100/1000 Mbps - switch - 8 ports - desktop | Device Type | Switch - 8 ports | Enclosure Type | Desktop | Ports | 8 x 10/100/1000 | MAC Address Table Size | 8K entries | Features | Full duplex capability, auto-sensing per device, auto-uplink (auto MDI/MDI-X) | Compliant Standards | IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab | Dimensions (WxDxH) | 28.7 cm x 10 cm x 2.5 cm | Weight | 0.9 kg | System Requirements | Apple MacOS, Novell NetWare, Microsoft Windows | Manufacturer Warranty | NETGEAR lifetime warranty |
General | |
Status Indicators | Port status, collision status, port transmission speed, power |
Expansion / Connectivity | |
Interfaces | 8 x 10Base-T/100Base-TX/1000Base-T - RJ-45 |
Power | |
Power Device | Power adapter - external |
Power Consumption Operational | 17.5 Watt |
Miscellaneous | |
Width | 15.5cm |
Depth | 10cm |
Height | 2.6cm |
Weight | 0.9 kg |
Mounting Kit | Included |
Compliant Standards | FCC Class A certified, C-Tick, cUL, EN55022, UL 1950, VCCI Class A ITE |
Software / System Requirements | |
OS Required | Apple MacOS, Novell NetWare, Microsoft Windows |
Manufacturer Warranty | |
Service & Support | NETGEAR lifetime warranty |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
