We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Netgear's ProSAFE 8 port 10/100 Desktop Switch enables the instant connection of up to eight Ethernet devices at speeds up to 100 Mbps.
The compact size and durable metal case allow for easy placement anywhere. It is backed by a lifetime warranty.
Product Description | NETGEAR FS108v3 - switch - 8 ports - unmanaged | Device Type | Switch - 8 ports - unmanaged | Subtype | Fast Ethernet | Ports | 8 x 10/100 | Performance | Bandwidth: 1.6 Gbps | MAC Address Table Size | 2K entries | Features | Flow control, auto-sensing per device, store and forward, 96KB packet buffer | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3x | Power | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) | 15.8 cm x 10.3 cm x 2.7 cm | Weight | 390 g | Localisation | United Kingdom | Manufacturer Warranty | NETGEAR lifetime warranty |
General | |
Enclosure Type | Desktop, wall-mountable |
Status Indicators | Port status, power, link/activity |
Expansion / Connectivity | |
Interfaces | 8 x 100Base-TX RJ-45 |
Power | |
Power Device | External power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Miscellaneous | |
Included Accessories | Wall mounting kit |
MTBF | 4,200,000 hours |
Compliant Standards | C-Tick, cUL, EN 60950, UL 1950, FCC Part 15 Class B, IEC 950, EN 55022/CISPR 22 Class A, RU EAC |
Dimensions & Weight | |
Width | 15.8 cm |
Depth | 10.3 cm |
Height | 2.7 cm |
Weight | 390 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - replacement - lifetime - response time: next business day , Limited warranty - power supply - 2 years , Technical support - lifetime |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 90% (non-condensing) |
Min Storage Temperature | -10 °C |
Max Storage Temperature | 70 °C |
Humidity Range Storage | 95% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
