Netgear's ProSAFE 8 port 10/100 Desktop Switch enables the instant connection of up to eight Ethernet devices at speeds up to 100 Mbps.
The compact size and durable metal case allow for easy placement anywhere. It is backed by a lifetime warranty.
Product Description | NETGEAR FS108v3 - switch - 8 ports - unmanaged | Device Type | Switch - 8 ports - unmanaged | Subtype | Fast Ethernet | Ports | 8 x 10/100 | Performance | Bandwidth: 1.6 Gbps | MAC Address Table Size | 2K entries | Features | Flow control, auto-sensing per device, store and forward, 96KB packet buffer | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3x | Power | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) | 15.8 cm x 10.3 cm x 2.7 cm | Weight | 390 g | Localisation | United Kingdom | Manufacturer Warranty | NETGEAR lifetime warranty |
General | |
Enclosure Type | Desktop, wall-mountable |
Status Indicators | Port status, power, link/activity |
Expansion / Connectivity | |
Interfaces | 8 x 100Base-TX RJ-45 |
Power | |
Power Device | External power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Miscellaneous | |
Included Accessories | Wall mounting kit |
MTBF | 4,200,000 hours |
Compliant Standards | C-Tick, cUL, EN 60950, UL 1950, FCC Part 15 Class B, IEC 950, EN 55022/CISPR 22 Class A, RU EAC |
Dimensions & Weight | |
Width | 15.8 cm |
Depth | 10.3 cm |
Height | 2.7 cm |
Weight | 390 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - replacement - lifetime - response time: next business day , Limited warranty - power supply - 2 years , Technical support - lifetime |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 90% (non-condensing) |
Min Storage Temperature | -10 °C |
Max Storage Temperature | 70 °C |
Humidity Range Storage | 95% (non-condensing) |
