NETGEAR 8-port Unmanaged Gigiabit Switch
£124.41
33 in stock
Delivery:
Standard: 1-3 working days
Key features
  • The standards-based Gigabit switches sense and adjust for network speed and cabling type automatically
  • Easily integrate into your existing Ethernet network - no matter if it is running at 10/100Mbps or Gigabit speed
  • Simple set up with no software or configuration needed
  • Front panel LEDs keep you informed of power status, link speed and link activities
  • Energy Efficient Ethernet (IEEE 802.3az) standard
  • Superior network performance at non-blocking rate delivers true Gigabit speed with no compromise
  • Type: Gigabit Ethernet
  • Ports: 8
  • Managed: No
  • POE: PoE+
  • Stock Status: In Stock
Product codes
The NETGEAR GS108PP is the industry’s first flexible PoE+ 8-Port Gigabit plug-and-play switch with 120W PoE budget. The Industry’s first flexible PoE+ integrated technology allows you to increase or decrease the PoE budget at any time to provide to your devices the power they need with interchangeable external power supply and an intuitive power selector. The flexible mounting options (rack-mount, wall-mount or desktop) and the compact and fanless design make the GS108PP an ideal option for any business or home.
Product Description NETGEAR GS108PP - switch - 8 ports - rack-mountable
Device Type Switch - 8 ports
Enclosure Type Rack-mountable
Subtype Gigabit Ethernet
Ports 8 x 10/100/1000 (PoE+)
Power Over Ethernet (PoE) PoE+
PoE Budget 123 W
Performance Bandwidth: 16 Gbps
MAC Address Table Size 4K entries
Jumbo Frame Support 9KB
Features Flow control, full duplex capability, store and forward, Weighted Fair Queuing (WFQ), Quality of Service (QoS), Energy Efficient Ethernet, 192KB packet buffer, Class of Service (CoS), DiffServ Code Point (DSCP) support, Energy-Efficient Ethernet (EEE), Weighted Round Robin (WRR)
Compliant Standards IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at, IEEE 802.3az
Power DC 54 V 2.4 A
Dimensions (WxDxH) 23.6 cm x 10.2 cm x 2.7 cm
Weight 590 g
Localisation Europe
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NETGEAR 8-port Unmanag...
£124.41
