NetGear 8 Port Unmanaged POE Switch
£73.99
Delivery:
Key features
  • Energy-efficient technology for power savings
  • Auto-MDI/MDIX eliminates the need for crossover cables
  • Non-blocking switching architecture for maximum throughput at wire speed
  • Auto-negotiation for automatic connection at the high common speed between switch and an end device
  • Fanless design for silent operation
  • Desktop or wall-mountable
  • Type: Gigabit Ethernet
  • Ports: 8
  • Managed: No
  • POE: PoE
Product codes
The NETGEAR SOHO Ethernet switches provide easy and affordable network connectivity to small offices and home/offices. They are easy to use, reliable, and rugged with metal enclosures. With these Plug-n-play switches, you can quickly and easily expand your network connections to multiple devices, with no configuration required. These switches also support various energy saving technologies, helping you save power and money.
Product Description NETGEAR SOHO Gigabit Ethernet Switch GS308P - switch - 8 ports - unmanaged
Device Type Switch - 8 ports - unmanaged
Subtype Gigabit Ethernet
Ports 4 x 10/100/1000 (PoE) + 4 x 10/100/1000
Power Over Ethernet (PoE) PoE
PoE Budget 53 W
Performance Bandwidth: 16 Gbps
MAC Address Table Size 4K entries
Jumbo Frame Support 9720 bytes
Features Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), Quality of Service (QoS), Green Ethernet, fanless, Energy Efficient Ethernet, security lock slot (cable lock sold separately), 1.5MB packet buffer
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3az
Dimensions (WxDxH) 15.8 cm x 10.1 cm x 2.9 cm
Weight 460 g
Localisation United Kingdom
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NetGear 8 Port Unmanag...
£73.99
