NETGEAR 8P Gige Easy-Mount POE+ Web Swch
Key features
  • 8 PoE+ ports to power up AC wave 2 access points, pan/tilt/zoom security cameras, VoIP/video conferencing phones, security door locks, etc.
  • Easy-mount virtually anywhere mounting system allows for wall, pole, under-surface, in-ceiling, and even two per 1U rack slot mounting (back-to-back) as all connections (power and Ethernet) are located on the front side
  • Secure placement above drop-down ceilings, or along ventillation ducts, and where other switch cannot go, vertical or horizontal, flat or perpendicular
  • Whisper quiet 26.9 dB acoustics when operating at 25°C (77°F), well below normal offices ambient background noise
  • Internal power supply to eliminate power brick
  • Turn LED lights on/off for non-distracting operation in dark environments
Product codes
The NETGEAR ProSAFE GS408EPP Easy-Mount 8-port Gigabit Ethernet PoE+ Web Managed Switch with 8 PoE+ ports features a unique "Virtually Anywhere"mounting system that allows to install more PoE+ ports exactly where you need them. The unique mounting system allows you to put the Easy Mount Switch up in the ceiling, strapped to a pole, mounted under a desk or tabletop, making it the perfect switch for deploying Wireless APs, Pan/Tilt/Zoom and fixed IP Cameras, VoIP Phones, access-limited security door locks or any other IoT PoE-powered devices. Should you decide to rack mount the GS408EPP switch, you can save space by installing two switches in just a single 1U slot. As a member of the NETGEAR Web Managed (Plus) Switch family, the GS408EPP also includes the full set of software features such as traffic prioritization, VLANs, QoS, Port Trunking/Link Aggregation and PoE power allocation. The GS408EPP also features Energy Efficient Ethernet (IEEE 802.3az) for maximum power savings.
Product Description NETGEAR Click GS408EPP - switch - 8 ports - Managed - rack-mountable
Device Type Switch - 8 ports - Managed
Enclosure Type Rack-mountable
Subtype Gigabit Ethernet
Ports 8 x 10/100/1000 (PoE+)
Power Over Ethernet (PoE) PoE+
PoE Budget 124 W
Performance Bandwidth: 16 Gbps , Latency (10 Mbps): <76.9µs , Latency (100 Mbps): <9.1µs , Latency (1000Base-T): <2.7µs , Forwarding performance (64-byte packet size): 11.9 Mfps
Capacity Virtual interfaces (VLANs): 64 , IGMP groups: 128 , Priority queues: 4
MAC Address Table Size 4K entries
Jumbo Frame Support 9000 bytes
Routing Protocol IGMP
Remote Management Protocol HTTP, TFTP
Features Flow control, VLAN support, IGMP snooping, DoS attack prevention, port mirroring, Weighted Round Robin (WRR) queuing, store and forward, Broadcast Storm Control, full duplex mode, firmware upgradable, vertical mounting, Quality of Service (QoS), horizontal mounting, Jumbo Frames support, pole mountable, DHCP client, Energy Efficient Ethernet, loop prevention, 192KB packet buffer, Multicast filtering function, Class of Service (CoS), tagged VLAN, Denial of Service (DoS), Type of Service (ToS), DiffServ Code Point (DSCP) support, cable test, Link Aggregation, Virtually Anywhere Mounting, Voice VLAN
Compliant Standards IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at, IEEE 802.3az
Dimensions (WxDxH) 38 cm x 10 cm x 4.3 cm
Weight 1.6 kg
Localisation Latin America, North America, Europe
Manufacturer Warranty ProSAFE lifetime warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
