NETGEAR 90W External Power Supply Unit
£38.05
Delivery:
Standard: 1-3 working days
Product codes
Future-proof your PoE budget. Increase or decrease your PoE budget anytime by simply upgrading your switch power supply, without having to purchase a new switch. Select NETGEAR Gigabit Ethernet Unmanaged Switches include a built-in PoE power selector lever, which lets you connect a compatible power adapter to increase or decrease the PoE power available on the switch.
Product Description NETGEAR 90W External Power Supply Unit (EPS90W) - power adapter - 90 Watt
Device Type Power adapter - external
Localisation United Kingdom
Output Voltage 54 V
Power Capacity 90 Watt
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NETGEAR 90W External P...
£38.05
