Start Flying with Next Generation WiFi
The world's fastest WiFi technology at your fingertips will enable even older Windows®-based laptops to soar at top speed. Simply plug the mini adapter into a USB slot to surf, stream or game - lag time free. NETGEAR dual band performance with Beamforming+ keeps you connected while improving range and reliability.
It's the latest WiFi standard. 3x faster than older standards and NETGEAR delivers it to your home network.
Beamforming+ Gives You Focus
As your laptops and mobile devices roam around the house, Beamforming+ follows you.
Smart and Reliable
Compatible with any standard WiFi router, this AC600 Dual Band WiFi USB Mini Adapter wirelessly upgrades your Windows®-based notebook computer to AC WiFi speeds. The compact, mini designed adapter is perfect for added mobility and allows you to experience lag-free, HD streams throughout your home, online gaming and a secure and reliable connection to the Internet. With up to 150/433Mbps speed, dual band and Beamforming+, the A6100 avoids interference ensuring top WiFi speeds and reliable connections. Easy setup with the NETGEAR® genie® gets you up and running fast, while Push `N' Connect gives you a secured connection at the push of a button.
Extended range and performance with 802.11ac (150 Mbps/433 Mbps)
Innovative mini-design
Perfect for online gaming and video streaming
Beamforming+--Faster, more reliable connections
Works with any standard WiFi Router or Modem Router/Gateway like Belkin®, Linksys®, D-Link®, NETGEAR®, & others
