NetGear A6100-100PES AC600 WiFi USB Mini Adapter 802.11 ac/n
£27.52
17 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Improve laptop Wi-Fi speed with AC
  • Works with 802.11 a/b/g/n and ac Wi-Fi routers
  • Beamforming technology boosts speed, range and reliability
  • Extended range and performance with 802.11 ac
  • Innovative mini-design
  • Stream HD videos simultaneously
  • Push 'N' connect - push button security
  • Wired / Wireless: Wireless
  • Protocol: IEEE 802.11a, IEEE 802.11ac, IEEE 802.11b, IEEE 802.11g + 1 more
  • Form Factor: External
  • Compatibility: PC
  • Type: Network adapter
Product codes
Start Flying with Next Generation WiFi
The world's fastest WiFi technology at your fingertips will enable even older Windows®-based laptops to soar at top speed. Simply plug the mini adapter into a USB slot to surf, stream or game - lag time free. NETGEAR dual band performance with Beamforming+ keeps you connected while improving range and reliability.
It's the latest WiFi standard. 3x faster than older standards and NETGEAR delivers it to your home network.
Beamforming+ Gives You Focus
As your laptops and mobile devices roam around the house, Beamforming+ follows you.
Smart and Reliable
Compatible with any standard WiFi router, this AC600 Dual Band WiFi USB Mini Adapter wirelessly upgrades your Windows®-based notebook computer to AC WiFi speeds. The compact, mini designed adapter is perfect for added mobility and allows you to experience lag-free, HD streams throughout your home, online gaming and a secure and reliable connection to the Internet. With up to 150/433Mbps speed, dual band and Beamforming+, the A6100 avoids interference ensuring top WiFi speeds and reliable connections. Easy setup with the NETGEAR® genie® gets you up and running fast, while Push `N' Connect gives you a secured connection at the push of a button.
Extended range and performance with 802.11ac (150 Mbps/433 Mbps)
Perfect for online gaming and video streaming
Beamforming+--Faster, more reliable connections
Works with any standard WiFi Router or Modem Router/Gateway like Belkin®, Linksys®, D-Link®, NETGEAR®, & others
Product Description NETGEAR A6100 WiFi USB Mini Adapter - network adapter
Device Type Network adapter
Form Factor External
Interface (Bus) Type USB
Dimensions (WxDxH) 3.61 cm x 1.84 cm x 0.81 cm
Weight 8 g
Data Link Protocol 802.11ac
Frequency Band 2.4 GHz, 5 GHz
Compliant Standards IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NetGear A6100-100PES A...
£27.52
