The AC1200 WiFi Range Extender Essentials Edition boosts WiFi range for speeds up to 1200 Mbps, suitable for HD video streaming and gaming. It works with any standard WiFi router and is suitable for iPads, smartphones, laptops and more. Its convenient size makes it one of the world’s smallest AC1200 wall-plug extenders.
Enjoy Life in The Fast Lane
With FastLane technology, use both Wi-Fi bands to establish one super speed connection; suitable for HD streaming and gaming.
Connectivity you Can't be Without
With one Gigabit ports that act as a Wi-Fi bridge, the AC1200 Wi-Fi range extender is also suitable for connecting devices like gaming consoles, smart TVs and streaming players to your Wi-Fi network, upgrading all of your entertainment devices to 11AC speed in a single shot.
Mobile Up to 100 Per Cent Faster
Improve your mobile Wi-Fi speeds by up to 100 per cent with AC1200 Wi-Fi range extender. External antennas help extend Wi-Fi coverage throughout large homes and even backyards. Experience what it means to be mobile.
In a Deadzone? Not Anymore
Is there a void space between your Wi-Fi router and your devices? Add a Wi-Fi range extender and strengthen your connection while improving connectivity.
Wi-Fi Analytics App
Use the NETGEAR Wi-Fi analytics app and get enhanced analytics to optimise your existing or newly extended Wi-Fi network. Check your network status, Wi-Fi signal strength, identify crowded Wi-Fi channels and much more. Here’s what you can do with the Wi-Fi Analytics App.
Product Description | NETGEAR EX6120 - Wi-Fi range extender | Device Type | Wi-Fi range extender | Form Factor | External | Localisation | United Kingdom | Data Link Protocol | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Frequency Band | 2.4 GHz, 5 GHz | Dimensions (WxDxH) | 5.517 cm x 3.9 cm x 6.717 cm | Weight | 130 g | Manufacturer Warranty | 2-year warranty |
General | |
Width | 5.517 cm |
Depth | 3.9 cm |
Height | 6.717 cm |
Weight | 130 g |
Networking | |
Connectivity Technology | Wireless |
Data Transfer Rate | 1200 Mbps |
Features | Auto-sensing per device, Wi-Fi Protected Setup (WPS), Push ‘N’ Connect button |
Encryption Algorithm | WPA-PSK, WPA2-PSK, WEP |
Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac |
Aerial | |
Antenna | External integrated |
Antenna Qty | 2 |
Expansion / Connectivity | |
Interfaces | 1 x 100Base-TX - RJ-45 |
Power | |
Power Device | Internal power supply |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
