NETGEAR AC1600 Smart WiFi Router -Dual Band
£60.16
19 in stock
Delivery:
Standard: 3-5 working days
Key features
  • Wide Wi-Fi range
  • Reliability
  • Easy sharing
  • Ease of use
  • Type: Wireless router
  • Standards: Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11a + 4 more
  • Stock Status: In Stock,
    Used stock also available below
Product codes
The NETGEAR AC1600 smart Wi-Fi router is an incredibly fast router delivering high Wi-Fi and Gigabit Ethernet speeds. External antennas provide improved Wi-Fi coverage for larger homes. It avoids wireless interference, ensuring top Wi-Fi speeds and reliable connections. Ideal for applications such as lag-free multiple video streaming, multi-player gaming, ultra-fast speed and a secure and reliable connection to the Internet.
Product Description NETGEAR R6260 - wireless router - 802.11a/b/g/n/ac - desktop
Device Type Wireless router - 4-port switch (integrated)
Enclosure Type Desktop
WAN Ports Qty 1
Data Link Protocol Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band 2.4 GHz / 5 GHz
Features Auto-sensing per device, Stateful Packet Inspection (SPI), DoS attack prevention, IPv6 support, parental control, Wi-Fi Protected Setup (WPS), FTP server, ReadySHARE, reset button, DLNA support, guest access, Advanced QoS, Circle Smart Parental Controls
Compliant Standards IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Dimensions (WxDxH) 23.551 cm x 15.076 cm x 5.45 cm
Weight 340 g
System Requirements UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7/8/10
Localisation United Kingdom
Manufacturer Warranty 1-year warranty
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been used but is in excellent condition
Ref: DF3M 042509
£50.64
product
Ref: DF3M 042509
Accessories
Packaging
Functional
Software
Manuals
£50.64
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NETGEAR AC1600 Smart W...
£60.16
