The NETGEAR AC1600 smart Wi-Fi router is an incredibly fast router delivering high Wi-Fi and Gigabit Ethernet speeds. External antennas provide improved Wi-Fi coverage for larger homes. It avoids wireless interference, ensuring top Wi-Fi speeds and reliable connections. Ideal for applications such as lag-free multiple video streaming, multi-player gaming, ultra-fast speed and a secure and reliable connection to the Internet.
Product Description | NETGEAR R6260 - wireless router - 802.11a/b/g/n/ac - desktop | Device Type | Wireless router - 4-port switch (integrated) | Enclosure Type | Desktop | WAN Ports Qty | 1 | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Frequency Band | 2.4 GHz / 5 GHz | Features | Auto-sensing per device, Stateful Packet Inspection (SPI), DoS attack prevention, IPv6 support, parental control, Wi-Fi Protected Setup (WPS), FTP server, ReadySHARE, reset button, DLNA support, guest access, Advanced QoS | Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Dimensions (WxDxH) | 23.551 cm x 15.076 cm x 5.45 cm | Weight | 340 g | System Requirements | UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7/8/10 | Localisation | United Kingdom | Manufacturer Warranty | 1-year warranty |
General | |
Connectivity Technology | Wireless, wired |
Encryption Algorithm | WPA-PSK, WPA2-PSK |
Wi-Fi AC Rating | AC1600 |
Processor | 880 MHz |
RAM | 128 MB |
Flash Memory | 128 MB |
Expansion / Connectivity | |
Interfaces | LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin mini-USB Type A |
Power | |
Power Device | External power adapter |
Miscellaneous | |
Cables Included | 1 x network cable |
Software / System Requirements | |
OS Required | UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7/8/10 |
Dimensions & Weight | |
Width | 23.551 cm |
Depth | 15.076 cm |
Height | 5.45 cm |
Weight | 340 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
