NETGEAR AC2200 Tri-Band Wallplug Wi-Fi Extender
£131.61
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Tri-Band Wi-Fi for faster speeds for more devices
  • MU-MIMO for simultaneously streaming to multiple devices
  • Works with any Wi-Fi router
  • Type: Wi-Fi range extender
  • Connectivity: Wireless
  • Speed: 2.2Gbps
  • Protocol: IEEE 802.11a, IEEE 802.11ac, IEEE 802.11b, IEEE 802.11g + 1 more
  • Stock Status: In Stock
Product codes
Nighthawk X4S AC2200 Tri-band Wi-Fi Range Extender provides speeds up to 2.2 Gbps while high-power internal antennas extend Wi-Fi range in hard-to-reach areas of your home. One Wi-Fi Name with any router uses the same Wi-Fi name as your existing Wi-Fi and provides seamless connectivity across router and extender as you roam throughout the house. Unlike other dual-band extenders, the Dedicated Wi-Fi Link helps establish an exclusive connection to the router that avoids automatic bandwidth reduction of extended Wi-Fi signals. Smart Roaming intelligently connects your mobile devices to the best available Wi-Fi for superior streaming as you move around your house.
Product Description NETGEAR Nighthawk X4S - Wi-Fi range extender
Device Type Wi-Fi range extender
Form Factor External
Localisation United Kingdom
Processor 1 x
Data Link Protocol IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band 2.4 GHz (1 band) / 5 GHz (2 bands)
Dimensions (WxDxH) 8.382 cm x 7.62 cm x 16.104 cm
Weight 304 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NETGEAR AC2200 Tri-Ban...
£131.61
