NetGear AC750 WiFi Range Extender + Extra Outlet
Key features
  • Boost AC750 Wi-Fi
  • Extra power outlet
  • Ethernet port
  • Simultaneous Dual Band Wi-Fi
  • External antennas
  • FastLane technology
Product codes
Boost the WiFi coverage in your home by adding the NETGEAR EX3800 AC750 Simultaneous Dual-Band WiFi Booster/Range Extender. With speeds up to 750Mbps and an extra Ethernet port, you can connect to speed for gaming and streaming via WiFi or a wired connection. Convenient wall-plug design lets you discreetly place the range extender where you need it, while the new pass-thru design lets you keep access to your outlet.
Key Features
  • Simultaneous dual band WiFi speeds of up to 750Mbps.
  • Provides an extra outlet to power additional devices.
  • Extend 2.4 and 5 GHz WiFi up to 750Mbps and reduce interference.
  • FastLane Technology to establish super high-speed connections.
  • Convenient wall-plug design with extra noise-filtered power outlet.
  • Ideal for online gaming and HD streaming on tablets, smart phones and TV.
  • Connect a wired device like a console or a smart TV to your WiFi network.
NETGEAR AC750 WiFi Range Extender EX3800 - Wi-Fi range extender
External
United Kingdom
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
6.4 cm x 4.45 cm x 11.4 cm
192 g
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NetGear AC750 WiFi Ran...
