NETGEAR AGM732F Fibre Gigabit 1000Base-LX (SC) SFP GBIC Module
£250.03
Delivery:
Standard: 1-3 working days
Key features
  • Adds fiber optic connectivity to the GSM7324, GSM7312, GSM7224, and FSM7326P;
  • Small size for high density fiber connections;
  • Meets SFP GBIC standard for use with any SFP GBIC compliant slot;
  • 1000BASE-LX connectivity over 10Km;
  • LC connector;
  • Works with 9 ┬Ám single mode cabling.
  • Type: Modules
  • Stock Status: In Stock
Product codes
The ProSAFE GBIC Module is a LC duplex connector and meets SFP GBIC standard for use with any SFP GBIC compliant slot.
Product Description NETGEAR ProSafe AGM732F - SFP (mini-GBIC) transceiver module - GigE
Device Type SFP (mini-GBIC) transceiver module - LC single-mode
Form Factor Plug-in module
Cabling Type 1000Base-LX
Data Transfer Rate 1 Gbps
Data Link Protocol GigE
Max Transfer Distance 10 km
Designed For NETGEAR GSM7224, M4300-28G-PoE+
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NETGEAR AGM732F Fibre...
£250.03
