NETGEAR Arlo Pro Plus Add-On Camera
£250.81
Delivery:
Standard: 1-3 working days
Key features
  • Details make the difference
  • Get the best of both worlds
  • Come rain or shine
Product codes
1080p HD lets you see everything that goes on at home in more brilliant detail than ever before. That means, if an intruder were to break into your home, Arlo's clear video quality can help you better identify the suspect.
Arlo Pro 2 has the flexibility to go wire-free thanks to its rechargeable battery, or stay plugged into power. When plugged in to an indoor power outlet, you unlock your security camera's advanced features, like Activity Zones and optional 24/7 continuous video recording.
Product Description Arlo Pro 2 VMC4030P - network surveillance camera
Device Type Network surveillance camera - fixed - outdoor - waterproof
Audio Yes: built-in speaker, two-way audio capability, built-in microphone
Dimensions (WxDxH) 7.93 cm x 4.86 cm x 7.05 cm
Weight 136 g
Connectivity Technology Wireless
Camera Colour - Day&Night
Max Resolution 1920 x 1080
Video Modes 1080p
Optical Sensor Type CMOS
Focal Length Control Fixed focal
Interfaces IEEE 802.11n
Features Motion sensor, e-mail alerts, weatherproof, Push Notification, built-in siren, auto white balance, sound sensor, infrared-cut filter, night vision
Environmental Parameters (operating) -20 °C - 45 °C
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NETGEAR Arlo Pro Plus...
£250.81
