The NETGEAR D6400 AC1600 Simultaneous Dual-Band VDSL2 WiFi Router is an incredibly fast modem router delivering AC1600 WiFi and Gigabit Ethernet speeds. This NETGEAR D6400 WiFi Router provides a fast VDSL modem for fibre broadband and it also works with ADSL connections. It offers the ultimate performance in wireless coverage for large homes with 10 or more devices. With this NETGEAR D6400 WiFi Router you get 3x faster access than with similar 802.11n technology and more reliable streaming.
Backward compatible
Compatible with AC WiFi devices and backward compatible with 802.11 a/b/g/n devices, this NETGEAR D6400 WiFi Router enables HD streaming throughout your home. With up to 300+1300 and simultaneous dual band WiFi technology, it avoids wireless interference, ensuring top WiFi speeds and reliable connections. In addition, Beamforming+ technology boosts speed, reliability and range of WiFi connections. These technologies also provide ultimate connectivity for dual band wireless devices like iPad and iPhone.
Extreme download speeds
Speed makes HD video better. Speed makes online gaming awesome. Speed makes all your devices really go. And anyplace you need speed, with NETGEAR you got it. Extreme download speeds up to 300+1300 Mbps. Next-generation 11ac WiFi with dual band technology providing whole home coverage with Gigabit wired and wireless connection. Everything you need for a fast, fast, fast connected home.
High-power amplifiers
Homes come in all shapes and sizes. This NETGEAR D6400 WiFi Router with additional high-power amplifiers provides WiFi connectivity throughout your home for all your Internet-enabled devices.
Sharing
Relive memories and share them with others. Find photos, videos and music stored on a shared USB hard drive and enjoy them on your DLNA TV right from your couch. If it's secure and shared storage access you want, NETGEAR has easy ways to do it.
Reliable connections
Stay connected with your devices, your media, and your friends. Simultaneous Dual Band WiFi provides two separate WiFi networks -- 2.4GHz for legacy devices and 5GHz which is less interference-prone for media streaming. The advanced QoS technology provides higher priority for media streaming application for smoother HD video streaming and low-latency online gaming.
Easy to use
NETGEAR makes it easy to do more with your digital devices. Manage your network with NETGEAR genie App - a personal, icon-based dashboard that can control and monitor all your devices. Or, use Push `N' Connect to add devices to your WiFi network with a push of a button. And the simple browser-based installation with no CD makes router installation easy using an iPad, tablet, smartphone, or computer.
Safe and secure browsing
Keep your Internet browsing experience safe and secure with the free parental controls. This NETGEAR D6400 WiFi Router allows you to limit access to certain web sites at certain times. For example, no social networking or gaming site access after dinner time. Guest networks create a completely separate WiFi network for your guests' devices, ensuring they do not have access to your home network or to the shared USB hard drive with all your personal data. Secure WiFi connections offer the highest level of WPA/WPA2 security.
Powerful home network
With this NETGEAR D6400 WiFi Router, create a powerful home network for applications such as lag-free, multiple HD streaming, multiplayer online gaming, ultra-fast, reliable connection to the Internet and a secure wireless connection.
Standard Warranty: 2-Years
Product Description | NETGEAR D6400 - wireless router - DSL modem - 802.11a/b/g/n/ac - desktop | Device Type | Wireless router - DSL modem - 4-port switch (integrated) | Enclosure Type | Desktop | Digital Signaling Protocol | VDSL, ADSL2+ | WAN Ports Qty | 2 | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Frequency Band | 2.4 GHz / 5 GHz | Data Transfer Rate | 1600 Mbps | Remote Management Protocol | HTTP | Features | Firewall protection, auto-sensing per device, NAT support, Stateful Packet Inspection (SPI), DoS attack prevention, IPv6 support, parental control, firmware upgradable, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), ReadySHARE, Push ‘N’ Connect button, Beamforming+ | Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac | Dimensions (WxDxH) | 19.1 cm x 6.5 cm x 19.85 cm | Weight | 422 g | System Requirements | UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7, Windows 8 | Localisation | United Kingdom | Manufacturer Warranty | 2-year warranty |
General | |
Device Type | Wireless router - 4-port switch (integrated) |
Connectivity Technology | Wireless, wired |
Encryption Algorithm | WPA-PSK, WPA2-PSK |
RAM | 128 MB |
Flash Memory | 128 MB |
Communications | |
Type | DSL modem |
Expansion / Connectivity | |
Interfaces | LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x VDSL / ADSL2+ - RJ-11 , USB 2.0: 2 x 4 pin USB Type A |
Aerial | |
Aerial | Internal |
Power | |
Power Device | External power adapter |
Miscellaneous | |
Included Accessories | POTS filter |
Cables Included | 1 x network cable , 1 x phone cable |
Software / System Requirements | |
OS Required | UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7, Windows 8 |
Dimensions & Weight | |
Width | 19.1 cm |
Depth | 6.5 cm |
Height | 19.85 cm |
Weight | 422 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
