NetGear EX7000-100UKS Nighthawk WiFi Range Extender AC1900 Du...
NetGear EX7000-100UKS Nighthawk WiFi Range Extender AC1900 Dual Band
£115.46
23 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Extreme dual band Wi-Fi speed
  • Dual core 1 GHz processor enables max Wi-Fi performance
  • High power amplifiers for extreme range
  • 3 external antennas for maximum signal coverage
  • FastLane technology improves performance using both Wi-Fi bands
  • 5 x Gigabit ports to connect wired devices like smart TVs and game consoles to Wi-Fi
  • Access point mode creates a Wi-Fi hotspot using a wired Ethernet connection
  • USB 3.0 for up to 10 times faster access to your stored media
  • DLNA server to play your media on TVs and game consoles
  • Access scheduling for parental controls
  • Whole home Wi-Fi coverage for your mobile devices
  • High-powered amplifiers and external antennas increase range
  • Web browser based settings accessible on most devices
  • Type: Wi-Fi range extender
  • Connectivity: Wireless
  • Speed: 1900Mbps
  • Protocol: Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11a + 4 more
  • Compatibility: Mac, PC
Product codes
The NETGEAR Nighthawk AC1900 Wi-Fi range extender boosts your existing network range & speed, delivering extreme dual band Wi-Fi up to 1900 Mbps. The high-powered amplifiers provide extreme range, while the dual core 1 GHz processor enables maximum Wi-Fi performance. It works with any standard Wi-Fi router & is ideal for HD video streaming & gaming. Get the whole-home connectivity you need for iPads, smartphones, laptops & more.
Boost your existing WiFi
Extend dual band WiFi up to 1900Mbps & reduce interference
External antennas for better WiFi coverage & more speed
5 Gigabit Ethernet Ports - Connect a wired device like Blu-ray player, game console, or smart TV to your WiFi network
Two WiFi Modes - Extend existing WiFi connection or create a new AC WiFi access point
FastLane Technology - Use both WiFi bands to establish one super high-speed connection; ideal for HD streaming & gaming
Extend - Extreme Range & Performance
Extreme dual band WiFi speed - up to 1900Mbps
Dual Core 1GHz processor enables max WiFi performance
3 external antennas for max signal coverage
FastLane technology improves performance using both WiFi bands
Stream - Ultimate Connectivity
5 Gigabit ports to connect wired devices like smart TVs and game consoles
Access Point mode creates a WiFi hotspot using a wired Ethernet connection
USB 3.0 for up to 10x faster access to your stored media
DLNA server to play your media on TVs & game consoles
Mobile - Up To 100% Faster
Whole home WiFi coverage for your mobile devices
Print from an iPad or iPhone - Make any printer AirPrint compatible
Optimize your WiFi network with the WiFi Analytics app for Android
WiFi Analytics App
How strong is your WiFi signal? Use the NETGEAR WiFi Analytics App & get advanced analytics to optimize your existing or newly extended WiFi network. Check your network status, WiFi signal strength, identify crowded WiFi channels & much more!
Product Description NETGEAR Nighthawk EX7000 - Wi-Fi range extender
Device Type Wi-Fi range extender
Form Factor External
Localisation United Kingdom
Processor 1 GHz
Ports Qty 5
Data Link Protocol Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band 2.4 GHz, 5 GHz
Included Accessories Vertical stand
Dimensions (WxDxH) 25.2 cm x 17.4 cm x 3.1 cm
Weight 654 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NetGear EX7000-100UKS...
£115.46
