NETGEAR Fibre Gigabit Module
£135.06
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Adds fiber optic connectivity to the GSM7324;
  • Small size for high-density fiber connections;
  • Meets SFP GBIC standard for use with any SFP GBIC compliant slot;
  • 1000BaseSX connectivity;
  • LC connectors;
  • Supports both 50um and 62.5um multimode fiber cables.
  • Type: Modules
Product codes
The ProSAFE GBIC Module is a LC duplex connector and meets SFP GBIC standard for use with any SFP GBIC compliant slot.
Product Description NETGEAR ProSafe AGM731F - SFP (mini-GBIC) transceiver module - GigE
Device Type SFP (mini-GBIC) transceiver module - LC multi-mode
Form Factor Plug-in module
Cabling Type 1000Base-SX
Data Transfer Rate 1 Gbps
Data Link Protocol GigE
Dimensions (WxDxH) 1.3 cm x 6.5 cm x 0.9 cm
Weight 50 g
Designed For NETGEAR M4300-28G-PoE+
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£135.06
