NetGear FS728TLP 24 Port 10/100 Smart Switch
£182.77
Delivery:
Key features
  • Twenty-four RJ-45 10/100 Fast Ethernet switch ports
  • Four RJ-45 10/100/1000 Gigabit Ethernet switch ports, two of which (27T and 28T) function as combo ports
  • Two small form-factor pluggable (SFP) GBIC slots, both of which (27F and 28F) function as combo ports
  • Autosensing and autonegotiating capabilities for all ports
  • Auto MDI/MIDX technology is supported on all ports
  • Automatic address-learning function to build the packet-forwarding information table
  • Full- and half-duplex functions for all 10/100/1000 Mbps ports
  • Store-and-forward transmission to remove corrupt packets from the network
  • Full-duplex IEEE 802.3x pause frame flow control
  • Active flow control to minimize packet loss and frame drops
  • Half-duplex back-pressure control
  • Per-port LEDs and system LEDs
  • Internal power supply
  • Standard 1U high, rack-mountable 19-inch chassis
  • Fan speed control
  • Support for the Power over Ethernet (PoE)
Product codes
The NETGEAR FS728TLP ProSafe 24-Port Smart Fast Ethernet PoE Switch provides 24 (twenty-four) 10/100BASE-T ports, 4 (four) 10/100/1000BASE-T ports, 2 (two) of which function as combo ports, and 2 (two) small form-factor pluggable (SFP) GBIC slots, both of which function as combo ports. Power over Ethernet (PoE) is supported on ports 1 through 12. The switchs management features include configuration for port and switch information, VLAN for traffic control, port trunking for increased bandwidth, and Class of Service (CoS) for traffic prioritisation.
Smart Management
The switch also provides the benefit of administrative management with a complete package of features to monitor, configure, and control the network. With the web management interface, you can view the switches many features and use them in a simple and intuitive manner. The NETGEAR FS728TLP switch management features include configuration for port and switch information, VLAN for traffic control, port trunking for increased bandwidth, and Class of Service (CoS) for traffic prioritisation. Initial discovery of the NETGEAR FS728TLPswitch on the network requires the Smart Control Center, a utility that runs on a computer.
Deployment and PoE
You can use the NETGEAR FS728TLP switch freestanding or rack-mounted in a wiring closet or equipment room. The switch is IEEE-compliant and provides low latency for high-speed networking. All port scan automatically negotiate to the highest speed. This capability makes the switch well suited for environments that have a mix of Ethernet, Fast Ethernet, and Gigabit Ethernet devices. In addition, all RJ-45 ports operate in half- or full-duplex mode. The maximum segment length is 328 feet (100 meters) over a Category 5 twisted-pair cable.
24 (twenty-four) x RJ-45 10/100 Fast Ethernet switch ports
4 (four) RJ-45 10/100/1000 Gigabit Ethernet switch ports
Autosensing and auto negotiating capabilities for all ports
Standard Warranty: Lifetime
Product Description NETGEAR FS728TLP - switch - 24 ports - Managed - rack-mountable
Device Type Switch - 24 ports - Managed
Enclosure Type Rack-mountable 1U
Subtype Fast Ethernet
Ports 12 x 10/100 (PoE) + 12 x 10/100 + 2 x 10/100/1000 + 2 x combo Gigabit SFP
Power Over Ethernet (PoE) PoE
PoE Budget 100 W
Capacity Virtual interfaces (VLANs): 128 , Priority queues per port: 8 , Layer 2 multicast groups: 128
MAC Address Table Size 8K entries
Routing Protocol IGMPv2, IGMP, IGMPv3
Remote Management Protocol SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, HTTP, TFTP
Features Flow control, VLAN support, IGMP snooping, DoS attack prevention, port mirroring, Broadcast Storm Control, full duplex mode, Multicast Storm Control, Unicast Storm Control, Weighted Random Early Detection (WRED), Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, DHCP snooping, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), LACP support, LLDP support, DHCP client, Energy Efficient Ethernet, 512KB packet buffer, Multicast filtering function, Class of Service (CoS), Denial of Service (DoS), 4MB packet buffer, 802.1x authentication, Type of Service (ToS), VoIP support, DiffServ Code Point (DSCP) support, cable test, administrator's password, Bridge protocol data unit (BPDU)
Compliant Standards IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1ab (LLDP), IEEE 802.3az
Dimensions (WxDxH) 44 cm x 20.4 cm x 4.3 cm
Weight 2.92 kg
Localisation Europe
Manufacturer Warranty NETGEAR lifetime warranty
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NetGear FS728TLP 24 Po...
£182.77
