NetGear Gigabit Ethernet 10/100/1000 Mbps 5port Switch 200 Se...
NetGear Gigabit Ethernet 10/100/1000 Mbps 5port Switch 200 Series
£11.04
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Energy-efficient technology for power savings
  • Auto-MDI/MDIX eliminates the need for crossover cables
  • Non-blocking switching architecture for maximum throughput at wire speed
  • Auto-negotiation for automatic connection at the highest common speed between switch and an end device
  • Fan-less design for quiet operation
  • Type: Gigabit Ethernet
  • Ports: 5
  • Data Transfer Rate: 1Gbps
  • Managed: No
  • POE: No
Product codes
The NETGEAR 200 series unmanaged switch provides easy and affordable network connectivity to home and small offices. It is easy to use and reliable. With these Plug-and-Play switch, you can expand your network connections to multiple devices instantly. The 200 series also supports the efficient use of energy, helping you save power and money.
Product Description NETGEAR GS205 - switch - 5 ports - unmanaged
Device Type Switch - 5 ports - unmanaged
Subtype Gigabit Ethernet
Ports 5 x 10/100/1000
Performance Bandwidth: 10 Gbps
MAC Address Table Size 4K entries
Features Auto-uplink (auto MDI/MDI-X), store and forward
Compliant Standards IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab
Dimensions (WxDxH) 11.4 cm x 8.6 cm x 2.6 cm
Weight 122 g
Localisation United Kingdom
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NetGear Gigabit Ethern...
£11.04
