We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The NETGEAR 200 series unmanaged switch provides easy and affordable network connectivity to home and small offices. It is easy to use and reliable. With these Plug-and-Play switch, you can expand your network connections to multiple devices instantly. The 200 series also supports the efficient use of energy, helping you save power and money.
Product Description | NETGEAR GS208 - switch - 8 ports - unmanaged | Device Type | Switch - 8 ports - unmanaged | Subtype | Gigabit Ethernet | Ports | 8 x 10/100/1000 | Performance | Bandwidth: 16 Gbps | MAC Address Table Size | 4K entries | Features | Auto-uplink (auto MDI/MDI-X), store and forward | Compliant Standards | IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab | Dimensions (WxDxH) | 15.2 cm x 9.3 cm x 2.6 cm | Weight | 192 g | Localisation | United Kingdom |
General | |
Enclosure Type | Desktop |
Status Indicators | Power, link/activity |
Expansion / Connectivity | |
Interfaces | 8 x 1000Base-T RJ-45 |
Power | |
Power Device | External power adapter |
Power Consumption Operational | 3.64 Watt |
Miscellaneous | |
Dimensions & Weight | |
Width | 15.2 cm |
Depth | 9.3 cm |
Height | 2.6 cm |
Weight | 192 g |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
