For a high-speed network on a small scale, nothing delivers likes these compact powerhouses. Equipped with five auto-sensing 10/100/1000 Mbps UTP ports, NETGEAR ProSafe GS105 switches give your network the capacity to handle huge workloads. If your network is configured to support jumbo frames, ProSafe GS105 switches will forward them, as well as honoring priority tags at both the layer 2 and layer 3 level. This means they move very large files across your network instantly, and keep the high priority traffic moving. Packed with ease-of-use features to simplify your networking experience, its trim design makes it an easy fit for a desk or mounted on a wall. The durable metal chassis protects interior working parts and the fanless design results in silent operation. Matched with NETGEAR's thorough testing, the ProSafe GS100 series switches provide long-lasting performance you can count on.
Product Description | NETGEAR GS105 - switch - 5 ports | Device Type | Switch - 5 ports | Subtype | Gigabit Ethernet | Ports | 5 x 10/100/1000 | MAC Address Table Size | 2K entries | Features | Full duplex capability, auto-sensing per device, auto-uplink (auto MDI/MDI-X), store and forward | Compliant Standards | IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.3p | Dimensions (WxDxH) | 9.4 cm x 10 cm x 2.7 cm | Weight | 0.3 kg | Localisation | United Kingdom | Manufacturer Warranty | NETGEAR lifetime warranty |
General | |
Enclosure Type | Desktop |
RAM | 128 KB |
Status Indicators | Collision status, port transmission speed, port duplex mode, power, link OK, link/activity |
Expansion / Connectivity | |
Interfaces | 5 x 10/100/1000 Base-T RJ-45 |
Power | |
Power Device | External power adapter |
Miscellaneous | |
Mounting Kit | Included |
Compliant Standards | FCC Class B certified, C-Tick, VCCI Class B ITE |
Dimensions & Weight | |
Width | 9.4 cm |
Depth | 10 cm |
Height | 2.7 cm |
Weight | 0.3 kg |
Manufacturer Warranty | |
Service & Support | NETGEAR lifetime warranty |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 50 °C |
Humidity Range Operating | Up to 90% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
