NETGEAR GS105 5 Port Gigabit Switch
CONNECTS UP TO 10X FASTER THAN FAST ETHERNET FOR MAXIMUM PERFORMANCE
£21.07
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Connects up to 10x faster than Fast Ethernet for maximum performance
  • Auto power-down mode saves energy when port is unused
  • Simple to combine Fast Ethernet and Gigabit devices in your network
  • Plug-and-play installation delivers ease of use
  • ProSafe 5-port Gigabit Desktop Switches connect your network with the dual advantages of performance and convenience
  • Fast, auto-switching Ethernet connection integrates 10, 100, and 1000 Mbps devices into your network
  • Supports Windows and Macintosh platforms
  • LEDs make it easy to monitor link, speed, and activity
  • AutoUplink technology automatically adjusts for two common types of cables
  • Compact metal case for desktop or wall mounting
  • Up to 60% lower power consumption
  • Packaging manufactured with at least 80% recycled materials
  • Type: Gigabit Ethernet
  • Ports: 5
  • Data Transfer Rate: 1Gbps
  • Managed: No
  • POE: No
Product codes
For a high-speed network on a small scale, nothing delivers likes these compact powerhouses. Equipped with five auto-sensing 10/100/1000 Mbps UTP ports, NETGEAR ProSafe GS105 switches give your network the capacity to handle huge workloads. If your network is configured to support jumbo frames, ProSafe GS105 switches will forward them, as well as honoring priority tags at both the layer 2 and layer 3 level. This means they move very large files across your network instantly, and keep the high priority traffic moving. Packed with ease-of-use features to simplify your networking experience, its trim design makes it an easy fit for a desk or mounted on a wall. The durable metal chassis protects interior working parts and the fanless design results in silent operation. Matched with NETGEAR's thorough testing, the ProSafe GS100 series switches provide long-lasting performance you can count on.
Product Description NETGEAR GS105 - switch - 5 ports
Device Type Switch - 5 ports
Subtype Gigabit Ethernet
Ports 5 x 10/100/1000
MAC Address Table Size 4K entries
Features Full duplex capability, auto-sensing per device, auto-uplink (auto MDI/MDI-X), store and forward
Compliant Standards IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.3p
Dimensions (WxDxH) 9.4 cm x 10.4 cm x 2.8 cm
Weight 0.3 kg
Localisation United Kingdom
Manufacturer Warranty NETGEAR lifetime warranty
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NETGEAR GS105 5 Port G...
£21.07
