The NETGEAR Gigabit unmanaged switch series helps businesses cost-effectively expand their network to Gigabit speeds and higher port counts.
Product Description | NETGEAR GS116LP - switch - 16 ports - rack-mountable | Device Type | Switch - 16 ports | Enclosure Type | Rack-mountable | Subtype | Gigabit Ethernet | Ports | 16 x 10/100/1000 (PoE+) | Power Over Ethernet (PoE) | PoE+ | PoE Budget | 76 W | Performance | Bandwidth: 32 Gbps | MAC Address Table Size | 4K entries | Features | Flow control, full duplex capability, store and forward, Weighted Fair Queuing (WFQ), Quality of Service (QoS), Jumbo Frames support, fanless, Energy Efficient Ethernet, 1MB packet buffer, Class of Service (CoS), DiffServ Code Point (DSCP) support, Energy-Efficient Ethernet (EEE), Weighted Round Robin (WRR) | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at, IEEE 802.3az | Power | DC 54 V | Dimensions (WxDxH) | 28.6 cm x 10.2 cm x 2.7 cm | Weight | 880 g | Localisation | United Kingdom, Europe | Manufacturer Warranty | Limited lifetime warranty |
General | |
Enclosure Type | Desktop, rack-mountable, wall-mountable |
PoE Budget | 76 W |
Status Indicators | Power, PoE, link/activity/speed |
Expansion / Connectivity | |
Interfaces | 16 x 1000Base-T RJ-45 PoE+ - 76 W |
Power | |
Power Device | External power adapter |
Voltage Required | DC 54 V |
Miscellaneous | |
Included Accessories | Wall mounting kit |
Rack Mounting Kit | Included |
MTBF | 2,088,514 hours |
Compliant Standards | VCCI, BSMI, ICES-003, CB, FCC Part 15, EN 60950-1, LVD, KC, EAC, RCM |
Dimensions & Weight | |
Width | 28.6 cm |
Depth | 10.2 cm |
Height | 2.7 cm |
Weight | 880 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - replacement - lifetime - response time: next business day , Limited warranty - power supply - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 90% (non-condensing) |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 70 °C |
Humidity Range Storage | 95% (non-condensing) |
