NETGEAR Insight 48-Port Gigabit Ethernet PoE+ Smart Cloud Switch
£763.92
Delivery:
Standard: 1-3 working days
Key features
  • 48-port Gigabit copper + 2-port Gigabit SFP fiber + 2-port 10-Gigabit SFP+ ports
  • 505W PoE budget available across 48 Gigabit Ethernet PoE+ ports (802.3at)
  • Local and remote monitoring and management with NETGEAR Insight app
  • Your choice of management interface with NETGEAR Insight Cloud Portal
  • Remote/Cloud-managed advanced switching made affordable
  • 7-day free trial of Insight Premium including the Insight Cloud Portal included with every 28-port and above Insight Managed Smart Cloud Switch
  • Type: Gigabit Ethernet
  • Ports: 52
  • Managed: Yes
  • POE: PoE+
  • Stock Status: In Stock
Product codes
The NETGEAR Insight Managed Smart Cloud GC752XP is the first 52-port Gigabit Ethernet PoE+ Switch from NETGEAR with anytime, anywhere remote/cloud management. Using either the NETGEAR Insight mobile app or the Insight Cloud Portal you can easily setup, monitor and manage your Insight Managed Switches, Wireless Access Points, and Business-class ReadyNAS storage. The NETGEAR GC752XP features 48 copper Gigabit Ethernet PoE+ ports, 2 SFP 1G and 2 SFP+ 10G Fiber ports for maximum flexibility and connectivity in your network. With its remote cloud manageability, 505W PoE total budget, and advanced L2+/L3 Lite features, it's the most versatile switch on the market for any environment!
Product Description NETGEAR Insight GC752XP - switch - 52 ports - smart - rack-mountable
Device Type Switch - 52 ports - L3 - smart
Enclosure Type Rack-mountable
Subtype Gigabit Ethernet
Ports 48 x 10/100/1000 (PoE+) + 2 x Gigabit SFP (uplink) + 2 x 10 Gigabit SFP+ (uplink)
Power Over Ethernet (PoE) PoE+
PoE Budget 505 W
Performance Fabric throughput: 140 Gbps , Forwarding performance (64-byte packet size): 104.2 Mpps
Capacity ACL: 100 , VLANs supported: 256 , Priority queues: 8 , IGMP multicast groups: 512 , IPv4 routes (static): 32 , IPv6 routes (static): 31
MAC Address Table Size 16K entries
Jumbo Frame Support 9KB
Routing Protocol IGMPv2, IGMP, IGMPv3, static IPv4 routing, static IPv6 routing, MLDv2, MLD
Remote Management Protocol SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP
Features ARP support, IGMP snooping, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, port mirroring, store and forward, Broadcast Storm Control, half duplex mode, full duplex mode, Multicast Storm Control, Unicast Storm Control, firmware upgradable, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping, Dynamic ARP Inspection (DAI), LACP support, LLDP support, DHCP relay, DHCP client, Energy Efficient Ethernet, Multicast VLAN Registration (MVR), dual firmware images, Strict Priority Queuing (SPQ), Neighbor Discovery Protocol (NDP), 2MB packet buffer, loop prevention, security lock slot (cable lock sold separately), Type of Service (ToS), DiffServ Code Point (DSCP) support, 3 fans, cable test, administrator's password, ICMP Router Discovery Protocol (IRDP), DNS client, guest access, Weighted Round Robin (WRR), loopback detection
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
Power AC 120/230 V (50 - 60 Hz)
Dimensions (WxDxH) 44 cm x 32 cm x 4.4 cm
Weight 4.79 kg
Localisation United Kingdom, Europe
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NETGEAR Insight 48-Por...
£763.92
