We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The NETGEAR VIZNTM GC510PP is the first App Managed Smart Cloud 8-port Gigabit Ethernet High-Power PoE+ Switch from NETGEAR with anywhere configuration and management. All you need is the NETGEAR Insight app for easy setup, monitoring and remote/cloud management of your VIZN Switches, VIZN Wireless Access Points, and Business-class ReadyNAS storage. The NETGEAR VIZN GC510PP features 8 PoE+ copper Gigabit Ethernet ports and 2 SFP Fiber ports with a total budget of 195 W for maximum flexibility and easy deployment in your network. With its remote cloud manageability, sleek design, high PoE power budget and whisper quiet operation, it's the most versatile switch on the market for any environment. Now you can setup, manage and monitor your network all from the palm of your hand and from anywhere in the world!
Product Description | NETGEAR Insight Managed GC510PP - switch - 8 ports - smart - rack-mountable | Device Type | Switch - 8 ports - L2+ - smart | Enclosure Type | Rack-mountable | Subtype | Gigabit Ethernet | Ports | 8 x 10/100/1000 (PoE+) + 2 x Gigabit SFP | Power Over Ethernet (PoE) | PoE+ | PoE Budget | 195 W | Performance | Fabric throughput: 20 Gbps , 1 Gbps copper latency (64-byte packets): 3000 µs , 1 Gbps fibre latency (64-byte packets): 2400 µs , Forwarding performance (64-byte packet size): 14.9 Mfps , 1 Gbps fibre latency (1518-byte packets): 2140 µs | Capacity | ACL: 100 , VLANs supported: 256 , Priority queues: 8 , IGMP multicast groups: 512 | MAC Address Table Size | 16K entries | Jumbo Frame Support | 9KB | Routing Protocol | IGMPv2, IGMP, IGMPv3, MLDv2, MLD | Remote Management Protocol | HTTP, HTTPS, TFTP | Features | Flow control, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, store and forward, Broadcast Storm Control, IPv6 support, full duplex mode, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping, Dynamic ARP Inspection (DAI), LLDP support, DHCP relay, Link Aggregation Control Protocol (LACP), DHCP client, Energy Efficient Ethernet, Multicast VLAN Registration (MVR), dual firmware images, Strict Priority Queuing (SPQ), loop prevention, security lock slot (cable lock sold separately), 802.1x authentication, cloud managed, Type of Service (ToS), 1.5MB packet buffer, cable test, administrator's password, PoE management, Link Aggregation, DNS client, 1 fan, protected ports, Weighted Round Robin (WRR) | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az, UPnP | Dimensions (WxDxH) | 31.4 cm x 18.8 cm x 4.4 cm | Weight | 2.23 kg | Localisation | United Kingdom, Europe | Manufacturer Warranty | 5-year warranty |
General | |
Enclosure Type | Desktop, rack-mountable, wall-mountable |
Encryption Algorithm | MD5, SSL, TLS, PEAP |
Authentication Method | RADIUS, TACACS+, Extensible Authentication Protocol (EAP) |
Processor | 1 Cortex-A9: 400 MHz |
RAM | 256 MB |
Flash Memory | 264 MB |
Status Indicators | Power, status, PoE, fan, link/activity/speed |
Expansion / Connectivity | |
Interfaces | 8 x 10/100/1000 Base-T RJ-45 PoE+ , 2 x 1000Base-X SFP |
Power | |
Power Device | Internal power supply |
Power Consumption Operational | 200 Watt |
Miscellaneous | |
Included Accessories | Wall mounting kit, foot pad set |
Rack Mounting Kit | Included |
MTBF | 381,503 hours |
Compliant Standards | BSMI CNS 13438 Class A, UL 60950-1 Second Edition, KCC, GB 9254-2008, K60950-1, RCM, BSMI CNS 14336-1, IEC 60950-1:2005 Second Edition, EN 61000-3-3:2013, FCC CFR47 Part 15 B Class A, GB 4943.1-2011, EN 55024:2010+A1:2015, KN32, KN35, EN 55032:2012+AC:2013 Class A, AS/NZS 60950-1:2015, CISPR 32:2015 Class A, CAN/CSA-C22.2 No. 60950-1-07 Second Edition, ICES-003:2016, EN 61000-3-2:2014 Class A, VCCI-CISPR 32:2016 Class A, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013 |
Dimensions & Weight | |
Width | 31.4 cm |
Depth | 18.8 cm |
Height | 4.4 cm |
Weight | 2.23 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - replacement - 5 years - response time: next business day , Technical support - 90 days |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 45 °C |
Humidity Range Operating | 0 - 90% (non-condensing) |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 70 °C |
Humidity Range Storage | 0 - 95% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
