NETGEAR Insight Managed 8-port Gigabit Ethernet PoE Smart Clo...
NETGEAR Insight Managed 8-port Gigabit Ethernet PoE Smart Cloud Switch
£76.99
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • One-touch management
  • Anywhere monitoring & management
  • All-inclusive connectivity & PoE (802.3af)
  • Smart switching
  • Modern design
  • Type: Gigabit Ethernet
  • Ports: 8
  • Managed: Yes
  • POE: PoE
  • Stock Status: In Stock
Product codes
The NETGEAR VIZNTM GC110P is the first App Managed Smart Cloud 8-port Gigabit Ethernet PoE Switch from NETGEAR with anywhere configuration and management. All you need is the NETGEAR Insight app for easy setup, monitoring and remote/cloud management of your VIZN Switches, VIZN Wireless Access Points, and Business-class ReadyNAS storage. The NETGEAR VIZN GC110P features 8 PoE copper Gigabit Ethernet ports and 2 SFP Fiber ports with a total budget of 62 W for maximum flexibility and easy deployment in your network. With its remote cloud manageability, sleek design, PoE power and fanless, silent operation, it's the most versatile switch on the market for any environment. Now you can setup, manage and monitor your network all from the palm of your hand and from anywhere in the world!
Product Description NETGEAR Insight Managed GC110P - switch - 8 ports - smart
Device Type Switch - 8 ports - L2+ - smart
Subtype Gigabit Ethernet
Ports 8 x 10/100/1000 (PoE) + 2 x Gigabit SFP
Power Over Ethernet (PoE) PoE
PoE Budget 62 W
Performance Fabric throughput: 20 Gbps , 1 Gbps copper latency (64-byte packets): 3000 µs , 1 Gbps fibre latency (64-byte packets): 2400 µs , Forwarding performance (64-byte packet size): 14.9 Mfps , 1 Gbps fibre latency (1518-byte packets): 2140 µs
Capacity ACL: 100 , VLANs supported: 256 , Priority queues: 8 , IGMP multicast groups: 512
MAC Address Table Size 16K entries
Jumbo Frame Support 9KB
Routing Protocol IGMPv2, IGMP, IGMPv3, MLDv2, MLD
Remote Management Protocol HTTP, HTTPS, TFTP
Features Flow control, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, store and forward, Broadcast Storm Control, IPv6 support, full duplex mode, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping, Dynamic ARP Inspection (DAI), fanless, LLDP support, DHCP relay, Link Aggregation Control Protocol (LACP), DHCP client, Energy Efficient Ethernet, Multicast VLAN Registration (MVR), dual firmware images, Strict Priority Queuing (SPQ), loop prevention, security lock slot (cable lock sold separately), 802.1x authentication, cloud managed, Type of Service (ToS), 1.5MB packet buffer, cable test, administrator's password, PoE management, Link Aggregation, DNS client, protected ports, Weighted Round Robin (WRR)
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3az, UPnP
Dimensions (WxDxH) 24.5 cm x 12.3 cm x 3.3 cm
Weight 770 g
Localisation United Kingdom
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NETGEAR Insight Manage...
£76.99
