NETGEAR LB1110 Wireless Cellular Modem GSM, UMTS, LTE, DC-HSPA+
Key features
  • Super-fast connectivity with 4G LTE & 3G
  • Wired connections
  • Better signal reception
Product codes
The NETGEAR 4G LTE Modem gives you a simple, LTE connectivity solution for your devices, avoiding disruptions in broadband when your fixed wire line goes down. Simply connect this modem directly to your router, switch or computer to provide an automatic 4G LTE or 3G/2G broadband backup connection with download speeds of up to 150 Mbps. It has a Gigabit Ethernet WAN port so that you can plug in your wireless router and share connection with all your Wi-Fi and wired devices. The NETGEAR 4G LTE Modem is also compact, convenient, and simple to setup.
NETGEAR LB1110 - wireless cellular modem - 4G LTE
Wireless cellular modem - Gigabit Ethernet
External
Europe
Max Transfer Rate
150 Mbps
Cellular Protocol
AC 230V
Apple MacOS X 10.6.8 or later, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
12 cm x 9.9 cm x 3.1 cm
150 g
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NETGEAR LB1110 Wireles...
