We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Intelligent Edge M4100 series consists of 12 fully managed switches ranging from 8-port Fast Ethernet to 50-port Gigabit Ethernet. They are ideal for all organizations considering reliable, affordable and simple access layer switching with CLI scripting, Layer 3 static routing as well as PoE scalability. As a cost-effective component of converged voice, video and data networking solutions, NETGEAR M4100 series delivers a secure, intelligent edge in commercial buildings and large campus LAN environments. PoE (802.3af) and PoE+ (802.3at) versions of M4100 series are perfect for Wireless access points, IP telephony, CCTV and video-surveillance deployments.
Product Description | NETGEAR M4100-D12G - switch - 12 ports - Managed | Device Type | Switch - 12 ports - L2+ - Managed | Subtype | Gigabit Ethernet | Ports | 12 x 10/100/1000 + 2 x shared SFP | Performance | Bandwidth: 24 Gbps | MAC Address Table Size | 16K entries | Routing Protocol | Static IPv4 routing | Remote Management Protocol | SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTPS, SSH, CLI | Features | Flow control, ARP support, VLAN support, IGMP snooping, Syslog support, port mirroring, DiffServ support, store and forward, Broadcast Storm Control, IPv6 support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, RADIUS support, MLD snooping, IPv4 support, fanless, LACP support, DHCP client, Multicast VLAN Registration (MVR), Class of Service (CoS) | Compliant Standards | IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1s, IEEE 802.3az | Power | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) | 32.8 cm x 16.9 cm x 4.32 cm | Weight | 1.33 kg | Localisation | Canada, United States, Europe | Manufacturer Warranty | NETGEAR lifetime warranty |
General | |
Enclosure Type | Desktop, wall-mountable |
Authentication Method | RADIUS, TACACS+ |
Status Indicators | Port status, power |
Expansion / Connectivity | |
Interfaces | 1 x 1000Base-T RJ-45 , 11 x 1000Base-T RJ-45 , 2 x SFP (mini-GBIC) , 1 x USB - 4 pin USB Type A , 1 x console - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin mini-USB Type B |
Power | |
Power Device | External power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 18.8 Watt |
Miscellaneous | |
Cables Included | 1 x USB cable |
Compliant Standards | CISPR 22 Class A, cUL, UL 1950, VCCI Class A ITE, EN55024, EN55022 Class A, EN50082-1, CB, CCC, FCC Part 15 A, C-Tick Class A |
Software / System Requirements | |
Software Included | Drivers & Utilities |
Dimensions & Weight | |
Width | 32.8 cm |
Depth | 16.9 cm |
Height | 4.32 cm |
Weight | 1.33 kg |
Manufacturer Warranty | |
Service & Support | NETGEAR lifetime warranty |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 50 °C |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 70 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
