NETGEAR M4200-10MG-POE+ Managed Switch
£855.08
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Provide eight full power PoE+ and multi-speed 1G, 2.5G ports combined with two 10G SFP+ uplinks
  • Allow for a fully non-blocking deployment of eight Wave 2 11ac access points, with 240W PoE budget
  • 8x2.5G to the access points and 2x10G line-rate aggregation to the wiring closet
  • Multi-speed 2.5G/5G for 100 meter Cat5e/Cat6 cable runs with 1G backward compatibility
Product codes
The NETGEAR ProSAFE M4200-10MG-PoE+ Managed Switch was designed from the ground up to optimize the installation of Wave 2 11ac access points. Includes eight full power PoE+ and multi-speed 1G, 2.5G ports for 100 meter cable runs, combined with two 10G uplinks for a fully non-blocking deployment of eight Wave 2 11ac access points. NETGEAR Multigigabit Ethernet is compatible with most major wireless and switching vendors managed solutions, and the only one with 8x2.5G to the AP and 2x10G line-rate aggregation to the wiring closet. Plenum rated, slim design and mounting accessories allow for access point placement optimization and cabling efficiency.
NETGEAR ProSAFE M4200 Intelligent Edge Series GSM4210P - switch - 10 ports - Managed - rack-mountable
Switch - 10 ports - L3 - Managed
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
6 x 100/1000/2.5G (PoE+) + 2 x 100/1000/2.5G/5G (PoE+) + 2 x 1 Gigabit / 10 Gigabit SFP+
Power Over Ethernet (PoE)
PoE+
PoE Budget
240 W
Performance
Switching capacity: 90 Gbps , Throughput: 66.9 Mpps
MAC Address Table Size
16K entries
Routing Protocol
RIP, static IPv4 routing, static IPv6 routing, MLD
Remote Management Protocol
SNMP, RMON, Telnet, HTTPS, SSH, CLI
DHCP support, VLAN support, IGMP snooping, Rapid Spanning Tree Protocol (RSTP) support, MLD snooping, side to side airflow, 16MB packet buffer
IEEE 802.3ad (LACP), IEEE 802.1AX
AC 120/230 V
Europe, Americas
NETGEAR lifetime warranty
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NETGEAR M4200-10MG-POE...
£855.08
