NETGEAR M4300 16-port 10GBASE-T Copper Managed Switch APS600W
£2,297.05
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Cost effective 1G access layer in campus LAN networks, and high performance 10G distribution layer for midsize organizations networks
  • Zero Touch AV-over-IP with pre-configured L2 Multicast on all 1G models (1G AV encoders and decoders) and 10G models (SDVoE-ready)
  • Advanced Layer 2, Layer 3 and Layer 4 feature set - no license required - including Policy Based Routing, RIP, VRRP, OSPF and PIM
  • Innovative mixed "Spine and Leaf", 1G and 10G stacking with nonstop forwarding and hitless failover redundancy
  • Low acoustics, half-width 16-port and 24-port 10G models can be paired in a single rack space for redundant Top of Rack
  • Up to 384 (Gigabit) ports, 768 (10 Gigabit) ports, 192 (40 Gigabit) ports or a combination in a stack seen as one "logical" switch
  • PoE+ (30 watts per port) with hot swap, redundant power supplies and full provisioning
  • Type: 10 Gigabit Ethernet
  • Ports: 16
  • Managed: Yes
  • POE: PoE+
  • Stock Status: In Stock
Product codes
Marketing description is not available.
Product Description NETGEAR M4300-16X - switch - 16 ports - Managed - rack-mountable
Device Type Switch - 16 ports - L3 - Managed - stackable
Enclosure Type Rack-mountable 1U
Subtype 10 Gigabit Ethernet
Ports 16 x 100/1000/2.5G/5G/10GBase-T (PoE+)
Power Over Ethernet (PoE) PoE+
PoE Budget 500 W
Performance Switching fabric bandwidth: 480 Gbps , Throughput: 238 Mpps
Capacity Packet buffer size: 16 MB
MAC Address Table Size 16K entries
Jumbo Frame Support 9KB
Routing Protocol RIP-2, IGMP, VRRP, OSPFv2, PIM-SM, static IP routing, PIM-DM, OSPFv3, PIM-SSM, ECMP, policy-based routing (PBR), MLD, MSTP, RSTP
Remote Management Protocol SNMP, RMON, Telnet, SNMP 3, HTTP, HTTPS, SSH-2, CLI, SCP, SFTP, DHCP, IPv4, IPv6, RSTP, TACACS+, RADIUS
Features BOOTP support, ARP support, auto-uplink (auto MDI/MDI-X), DoS attack prevention, DiffServ support, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, SNTP support, Non-Stop Forwarding (NSF), sFlow, Per-VLAN Spanning Tree Plus (PVST+), Uni-Directional Link Detection (UDLD), LLDP support, DHCP relay, Link Aggregation Control Protocol (LACP), Remote Switch Port Analyzer (RSPAN), Per-VLAN Rapid Spanning Tree (PVRST), Management Information Base (MIB), dual firmware images, Class of Service (CoS), Precision Time Protocol (PTP), Spanning-tree Root Guard (STRG), Authentication, Authorization and Accounting (AAA), User Datagram Protocol (UDP), Protocol Independent Multicast (PIM)
Compliant Standards IEEE 802.1p, IEEE 802.3af, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az, IEEE 802.1AX
Power AC 120/230 V
Dimensions (WxDxH) 21.2 cm x 34.5 cm x 4.4 cm
Weight 3.22 kg
Localisation United States, Europe
Manufacturer Warranty NETGEAR lifetime warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NETGEAR M4300 16-port...
£2,297.05
