NETGEAR M4300-24X24F Managed Switch
£4,611.28
Delivery:
Standard: 1-3 working days
Key features
  • The M4300-24X24F switch provides 24-port 10GBASE-T and 24-port 10GBASE-X SFP+
  • All (48) 10G ports are independent and 1G backward compatible for progressive transition to 10G speeds
  • With 960Gbps non-blocking fabric, M4300-24X24F delivers L2/L3/L4 and IPv4/IPv6 rich services for virtualization (Auto-iSCSI prioritization), server / storage interconnect and SMB core applications
  • Virtual Chassis stacking provides non-stop forwarding (NSF) and hitless failover for highest availability (HA)
  • Dual redundant, modular power supplies contribute to business continuity management
  • Type: 10 Gigabit Ethernet
  • Ports: 48
  • Managed: Yes
Product codes
The NETGEAR M4300 Switch Series delivers L2/L3/L4 and IPv4/IPv6 rich services for enterprise edge and SMB aggregation deployments with unrivaled ease of use: 10 Gigabit models can seamlessly stack with 1 Gigabit models within the series. Non-stop forwarding virtual chassis architectures provide advanced High Availability (HA) with hitless failover, that is, distributed link aggregation allows for load balancing and virtually zero downtime. License-free L3 feature set includes static routing, policy-based routing, RIP, VRRP, OSpiv as well as Multicast PIM routing. The NETGEAR M4300 Switch Series is ready for the future, with Software-defined Network (SDN) and OpenFlow 1.3 enabled for your network.
M4300-24X24F comes with 24 ports 10GBASE-T and 24 ports 10GBASE-X SFP+ in a full-width form factor. All 48 ports are independent and 1G backward compatible for progressive transition to 10G speeds. Ideal for Top-of-Rack server and storage applications: 1+1 PSU protection and front to back cooling ensure hot and cold aisle compliance. M4300-24X24F is line-rate with 960Gbps fabric for SMB core applications as well as spine and leaf stacking architectures.
Product Description NETGEAR M4300-24X24F - switch - 48 ports - Managed - rack-mountable
Device Type Switch - 48 ports - L3 - Managed - stackable
Enclosure Type Front to back airflow rack-mountable 1U
Subtype 10 Gigabit Ethernet
Ports 24 x 10/100/1000/10000 + 24 x 10 Gigabit SFP+
Performance Switching capacity: 960 Gbps , Throughput: 714 Mpps
Capacity Virtual interfaces (VLANs): 4000
Routing Protocol OSPF, RIP, IGMPv2, IGMP, VRRP, PIM-SM, PIM-DM, IGMPv3, MLDv2
Remote Management Protocol SNMP, Telnet, HTTPS, SSH, CLI
Features ARP support, DiffServ support, IPv6 support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Virtual Route Redundancy Protocol (VRRP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping, STP Root Guard, IPv4 support, LACP support, DHCP relay, Remote Switch Port Analyzer (RSPAN), Per-VLAN Rapid Spanning Tree (PVRST), dynamic ARP protection, IP source guard, Bridge protocol data unit (BPDU), LISP Across Subnet Mode (ASM), Source-Specific Multicast (SSM)
Compliant Standards IEEE 802.3ad (LACP), IEEE 802.3az
Power AC 120/230 V
Localisation Europe, Americas
Manufacturer Warranty NETGEAR lifetime warranty
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£4,611.28
