NETGEAR M4300-28G Managed Switch
£948.75
23 in stock
Delivery:
Standard: 1-3 working days
Key features
  • The M4300-28G switch provides 24 Gigabit access ports with 2 10GBASE-T and 2 10GBASE-X SFP+ uplink connectivity
  • All (4) 10G ports are independent and 1G backward compatible for progressive transition to 10G speeds
  • With 128Gbps non-blocking fabric, M4300-28G delivers L2/L3/L4 and IPv4/IPv6 rich services for virtualization (Auto-iSCSI prioritization), wireless access layer, IP video and unified communications
  • Virtual Chassis stacking provides non-stop forwarding (NSF) and hitless failover for highest availability (HA)
  • 1 Gigabit models such as M4300-28G seamlessly stack with 10 Gigabit models enabling line-rate spine and leaf topologies
Product codes
The NETGEAR M4300 Switch Series delivers L2/L3/L4 and IPv4/IPv6 rich services for enterprise edge and SMB aggregation deployments with unrivaled ease of use: 10 Gigabit models can seamlessly stack with 1 Gigabit models within the series. Non-stop forwarding virtual chassis architecture provides advanced High Availability (HA) with hitless failover, that is, distributed link aggregation allows for load balancing and virtually zero downtime. License-free L3 feature set includes static routing, policy-based routing, RIP, VRRP, OSpiv as well as Multicast PIM routing. The NETGEAR M4300 Switch Series is ready for the future, with Software-defined Network (SDN) and OpenFlow 1.3 enabled for your network.
M4300-28G comes with 24 ports 1G, 2 ports 10GBASE-T and 2 ports 10GBASE-X SFP+ in a full-width form factor. All 4 ports 10G are independent and can be used for stacking or uplinks: they are 1G backward compatible. M4300-28G is delivering resilient and secure access layer in campus LAN environments and commercial buildings. Ideal for server and storage applications: 1+1 PSU protection and front to back cooling ensure hot and cold aisle compliance.
NETGEAR ProSAFE M4300-28G - switch - 28 ports - Managed - rack-mountable
Switch - 28 ports - L3 - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
2 x 10/100/1000/10000 + 2 x 10 Gigabit SFP+ + 24 x 10/100/1000
Performance
Switching capacity: 128 Gbps
Routing Protocol
OSPF, RIP, IGMPv2, IGMP, VRRP, PIM-SM, PIM-DM, IGMPv3, MLDv2
Remote Management Protocol
SNMP, Telnet, HTTPS, SSH, CLI
ARP support, DiffServ support, IPv6 support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Virtual Route Redundancy Protocol (VRRP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping, front to back airflow, STP Root Guard, IPv4 support, LACP support, DHCP relay, Remote Switch Port Analyzer (RSPAN), Per-VLAN Rapid Spanning Tree (PVRST), dynamic ARP protection, IP source guard, Bridge protocol data unit (BPDU), LISP Across Subnet Mode (ASM), Source-Specific Multicast (SSM)
IEEE 802.3ad (LACP), IEEE 802.3az
AC 120/230 V
Europe, Americas
NETGEAR lifetime warranty
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NETGEAR M4300-28G Mana...
£948.75
