NETGEAR M4300-96X Managed Switch 48xSFP+ APS600W Starter Kit
£6,722.95
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Cost effective 1G access layer in campus LAN networks, and high performance 10G distribution layer for midsize organizations networks
  • Zero Touch AV-over-IP with pre-configured L2 Multicast on all 1G models (1G AV encoders and decoders) and 10G models (SDVoE-ready)
  • Advanced Layer 2, Layer 3 and Layer 4 feature set - no license required - including Policy Based Routing, RIP, VRRP, OSPF and PIM
  • Innovative mixed "Spine and Leaf", 1G and 10G stacking with nonstop forwarding and hitless failover redundancy
  • Low acoustics, half-width 16-port and 24-port 10G models can be paired in a single rack space for redundant Top of Rack
  • Up to 384 (Gigabit) ports, 768 (10 Gigabit) ports, 192 (40 Gigabit) ports or a combination in a stack seen as one "logical" switch
  • PoE+ (30 watts per port) with hot swap, redundant power supplies and full provisioning
  • 48- and 96-port 10G models' ultra-low latency and scalable table size with 128K MAC, 8K ARP/NDP, 4K VLANs, 12K routes
  • Mixed Stack of 1G and 10G models provides 16K MAC, 2K ARP/NDP, 4K VLANs and 512 routes
  • SDN-Ready OpenFlow 1.3 support for maximum investment protection
  • Type: 10 Gigabit Ethernet
  • Ports: 48
  • Managed: Yes
  • Stock Status: In Stock
Product codes
The NETGEAR M4300-96X is a 2RU modular switch that comes either empty or pre-populated with 48 SFP+ ports and supporting up to 96-port 10GBASE-T copper (RJ-45) with first 48 ports capable of PoE+, 96-port 10GBASE-X fiber (SFP+), 24-port 40GBASE-X fiber (QSFP+), or a combination. The M4300 family provides world-class services for server and storage interconnect, mid-enterprise edge and SMB core. SDVoE-Ready, M4300 switches streamline AV-over-IP deployments with Zero Touch multicast. Layer 3 feature set includes static, policy-based and dynamic routing as standard.
Product Description NETGEAR M4300-96X - Starter Kit - switch - 48 ports - Managed - rack-mountable
Device Type Switch - 48 ports - L3 - Managed - stackable
Enclosure Type Front to back airflow rack-mountable 1U
Subtype 10 Gigabit Ethernet
Ports 48 x 10 Gigabit SFP+
Performance Switching capacity: 1.92 Tbps , Throughput: 2.857 Mpps , 10 Gbps fibre latency (64-byte packets): 0.75 µs , 10 Gbps fibre latency (512-byte packets): 1.17 µs , 10 Gbps fibre latency (1024-byte packets): 1.603 µs , 10 Gbps fibre latency (1518-byte packets): 1.97 µs
Capacity Virtual interfaces (VLANs): 4093 , IPv4 routes (static): 64 , IPv6 routes (static): 64 , RIP routes: 512 , ARP entries: 8000 , OSPF routes: 12000 , NDP entries: 8000
MAC Address Table Size 256K entries
Jumbo Frame Support 9KB
Routing Protocol OSPF, RIP, IGMPv2, IGMP, VRRP, PIM-SM, PIM-DM, IGMPv3, MLDv2
Remote Management Protocol SNMP 1, SNMP 2, Telnet, SNMP 3, HTTPS, SSH, CLI
Features Modular design, ARP support, DiffServ support, IPv6 support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Virtual Route Redundancy Protocol (VRRP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping, STP Root Guard, IPv4 support, LACP support, DHCP relay, Remote Switch Port Analyzer (RSPAN), Per-VLAN Rapid Spanning Tree (PVRST), dynamic ARP protection, Neighbor Discovery Protocol (NDP), IP source guard, Bridge protocol data unit (BPDU), LISP Across Subnet Mode (ASM), Source-Specific Multicast (SSM), 96MB packet buffer
Compliant Standards IEEE 802.3ad (LACP), IEEE 802.3az, IEEE 802.1AX
Power AC 120/230 V
Dimensions (WxDxH) 53.5 cm x 44 cm x 8.8 cm
Weight 16.28 kg
Localisation Europe, Americas
Manufacturer Warranty ProSAFE lifetime warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NETGEAR M4300-96X Mana...
£6,722.95
