The NETGEAR M4300-96X is a 2RU modular switch that comes either empty or pre-populated with 48 SFP+ ports and supporting up to 96-port 10GBASE-T copper (RJ-45) with first 48 ports capable of PoE+, 96-port 10GBASE-X fiber (SFP+), 24-port 40GBASE-X fiber (QSFP+), or a combination. The M4300 family provides world-class services for server and storage interconnect, mid-enterprise edge and SMB core. SDVoE-Ready, M4300 switches streamline AV-over-IP deployments with Zero Touch multicast. Layer 3 feature set includes static, policy-based and dynamic routing as standard.
Product Description | NETGEAR M4300-96X - Starter Kit - switch - 48 ports - Managed - rack-mountable | Device Type | Switch - 48 ports - L3 - Managed - stackable | Enclosure Type | Front to back airflow rack-mountable 1U | Subtype | 10 Gigabit Ethernet | Ports | 48 x 10 Gigabit SFP+ | Performance | Switching capacity: 1.92 Tbps , Throughput: 2.857 Mpps , 10 Gbps fibre latency (64-byte packets): 0.75 µs , 10 Gbps fibre latency (512-byte packets): 1.17 µs , 10 Gbps fibre latency (1024-byte packets): 1.603 µs , 10 Gbps fibre latency (1518-byte packets): 1.97 µs | Capacity | Virtual interfaces (VLANs): 4093 , IPv4 routes (static): 64 , IPv6 routes (static): 64 , RIP routes: 512 , ARP entries: 8000 , OSPF routes: 12000 , NDP entries: 8000 | MAC Address Table Size | 256K entries | Jumbo Frame Support | 9KB | Routing Protocol | OSPF, RIP, IGMPv2, IGMP, VRRP, PIM-SM, PIM-DM, IGMPv3, MLDv2 | Remote Management Protocol | SNMP 1, SNMP 2, Telnet, SNMP 3, HTTPS, SSH, CLI | Features | Modular design, ARP support, DiffServ support, IPv6 support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Virtual Route Redundancy Protocol (VRRP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping, STP Root Guard, IPv4 support, LACP support, DHCP relay, Remote Switch Port Analyzer (RSPAN), Per-VLAN Rapid Spanning Tree (PVRST), dynamic ARP protection, Neighbor Discovery Protocol (NDP), IP source guard, Bridge protocol data unit (BPDU), LISP Across Subnet Mode (ASM), Source-Specific Multicast (SSM), 96MB packet buffer | Compliant Standards | IEEE 802.3ad (LACP), IEEE 802.3az, IEEE 802.1AX | Power | AC 120/230 V | Dimensions (WxDxH) | 53.5 cm x 44 cm x 8.8 cm | Weight | 16.28 kg | Localisation | Europe, Americas | Manufacturer Warranty | ProSAFE lifetime warranty |
General | |
Max Units In A Stack | 8 |
Authentication Method | RADIUS, TACACS+ |
Processor | 1: 1.4 GHz |
RAM | 2 GB |
Flash Memory | 256 MB |
Expansion / Connectivity | |
Interfaces | 1 x management (Gigabit LAN) RJ-45 , 1 x serial (RS-232) RJ-45 , 1 x console (mini-USB) , 1 x USB Type A , 48 x 10GBase-X SFP+ |
Expansion Slots | 12 (total) / 6 (free) |
Power | |
Power Device | Internal power supply |
Installed Qty | 1 |
Max Supported Qty | 2 |
Power Provided | 600 Watt |
Voltage Required | AC 120/230 V |
Power Consumption Operational | 566 Watt |
Miscellaneous | |
Included Accessories | 6 x I/O module blank slot covers |
Cables Included | 1 x mini-USB type B to USB type A power cable , 1 x console cable |
Rack Mounting Kit | Included |
Compliant Standards | BSMI, EN 60950, UL 1950, IEC 60950, CB, FCC CFR47 Part 15, LVD, RCM, BSMI CNS 14336-1, EN 61000-3-3:2013, YD/T993-1998, EN 61000-3-2:2014, CNS 13438 Class A, GB 4943.1-2011, EN 55032:2012+AC:2013 Class A, ANSI C63.4-2014, ISED, ICES-003:2016 issue 6 Class A, CISPR 32:2012, VCCI-CISPR 32:2016 Class A, AN/NZS 60950.1:2015, AS/NZS CISPR32:2013 Class A, IEC 60950-1:2005 (ed.2)+A1:2009+A2:2013, EN 55024:2010 Class A, T9254-2008 (Class A), EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013 |
Dimensions & Weight | |
Width | 53.5 cm |
Depth | 44 cm |
Height | 8.8 cm |
Weight | 16.28 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 50 °C |
Humidity Range Operating | 95% (non-condensing) |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 70 °C |
Humidity Range Storage | 95% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
