We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The ProSAFE M6100 Switch Series consists of Gigabit access layer and 10 Gigabit distribution layer switches in NETGEAR modular chassis switch product line. The M6100 switch series offers high-quality, high-density chassis alternative to stackable switches in campus LAN and midsize organizations demanding networks. With more than 1.4 Tbps switching and routing capacity, passive backplane, management and fabric nonstop forwarding redundancy, the M6100 series delivers world-class resiliency and scalability. Ultimately, operating software and system management features take the complexity out of delivering L2/L3/L4 rich services for enterprise edge and SMB core deployments.
Product Description | NETGEAR M6100-44G3-POE+ - Starter Kit - switch - 44 ports - Managed - rack-mountable | Device Type | Switch - 44 ports - L4 - Managed | Enclosure Type | Rack-mountable 4U | Subtype | Gigabit Ethernet | Ports | 40 x 10/100/1000 + 2 x 10Gb Ethernet + 2 x 10 Gigabit SFP+ | Power Over Ethernet (PoE) | PoE+ | Capacity | Virtual interfaces (VLANs): 4000 , Static routes: 512 , RIP routes: 512 , OSPF routes: 12000 , BGP routes: 12000 , ARP entries: 8000 , IPv4 forwarding table entries: 1536 , IPv6 forwarding table entries: 512 | MAC Address Table Size | 32000 entries | Jumbo Frame Support | 12KB | Routing Protocol | OSPF, BGP-4, RIP-1, RIP-2, BGP, IGMPv2, DVMRP, VRRP, OSPFv2, PIM-SM, PIM-DM, IGMPv3, OSPF for IPv6, OSPFv3, static IPv4 routing, static IPv6 routing, ECMP, policy-based routing (PBR), MLDv2, PIM-SMv6, BGP for IPv6, PIM-DMv6 | Remote Management Protocol | SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, HTTP, HTTPS, SSH, CLI | Features | BOOTP support, ARP support, trunking, VLAN support, IGMP snooping, Syslog support, traffic shaping, DoS attack prevention, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, store and forward, MAC address filtering, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, Weighted Fair Queuing (WFQ), Weighted Random Early Detection (WRED), sFlow, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Per-VLAN Spanning Tree (PVST), Multiple Spanning Tree Protocol (MSTP) support, Data Center Bridging Exchange (DCBX) support, priority-based flow control, DHCP snooping, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), DHCP server, MLD snooping, Dynamic ARP Inspection (DAI), STP Root Guard, Uni-Directional Link Detection (UDLD), Deficit Weighted Round Robin (DWRR), LLDP support, DHCP relay, Remote Switch Port Analyzer (RSPAN), Per-VLAN Rapid Spanning Tree (PVRST), DHCP client, Energy Efficient Ethernet, Management Information Base (MIB), dual firmware images, Multiple VLAN Registration Protocol (MVRP), Strict Priority Queuing (SPQ), Class of Service (CoS), tagged VLAN, Generic Attribute Registration Protocol (GARP), IGMP proxy, Type of Service (ToS), DiffServ Code Point (DSCP) support, MLD proxy, FCoE Initialization Protocol (FIP) | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.3ac, IEEE 802.1s, IEEE 802.1v, IEEE 802.1as, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az, IEEE 802.1AX, IEEE 802.1Qbb, IEEE 802.1Qaz | Power | AC 120/230 V (50/60 Hz) | Power Redundancy | Optional | Dimensions (WxDxH) | 43.2 cm x 44.16 cm x 17.59 cm | Manufacturer Warranty | NETGEAR lifetime warranty |
General | |
Encryption Algorithm | AES, TLS 1.0, SSL 3.0 |
Authentication Method | Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2) |
Processor | 1: 800 MHz |
RAM | 1 GB |
Flash Memory | 64 MB |
Status Indicators | Port transmission speed, power, status, link/activity, supervisor |
Expansion / Connectivity | |
Interfaces | 40 x 1000Base-T RJ-45 PoE+ - 30 W , 2 x 10GBase-T RJ-45 , 2 x 10GBase-X SFP+ , 1 x management (Gigabit LAN) RJ-45 , 1 x serial RJ-45 , 1 x management (mini-USB) , 1 x USB Type A |
Expansion Slots | 3 (total) / 2 (free) x Expansion Slot |
Installed Modules Qty (Max) | 1 (installed) / 3 (max) |
Power | |
Power Device | Internal power supply - hot-plug |
Installed Qty | 1 |
Max Supported Qty | 4 |
Power Redundancy Scheme | N+1 |
Power Provided | 1000 Watt |
Voltage Required | AC 120/230 V (50/60 Hz) |
80 PLUS Certification | 80 PLUS |
Features | Redundant Power System (RPS) connector |
Miscellaneous | |
Included Accessories | Fan tray |
Rack Mounting Kit | Included |
Compliant Standards | CISPR 22 Class A, cUL, EN 60950, IEC950, UL 1950, EN55024, CSA 22.2 No. 950, EN55022 Class A, EN50082-1, FCC Part 15 A, C-Tick Class A, VCCI Class A |
Dimensions & Weight | |
Width | 43.2 cm |
Depth | 44.16 cm |
Height | 17.59 cm |
Manufacturer Warranty | |
Service & Support | Limited warranty - replacement - lifetime - response time: next business day , Technical support - phone consulting - 90 days , Technical support - e-mail consulting - 90 days , Technical support - web support - lifetime |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 50 °C |
Humidity Range Operating | 0 - 90% (non-condensing) |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 70 °C |
Humidity Range Storage | 0 - 95% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
