NetGear Next-Gen Edge M5300-28GF3 Managed Switch
£1,500.69
Delivery:
Notify me
Key features
  • Embedded 10 Gigabit 10GBase-T/SFP+ uplinks
  • Top of the line access layer for 10GbE backbones
  • Line-rate for virtualization and convergence
  • Innovative multi-vendor Auto-iSCSI optimization
  • You can save costs now and should applications arise, there's seamless upgrade path with layer 3 licenses
  • Two embedded 10 Gigabit interfaces streamline network uplinks with SFP+ and 10GBase-T (RJ45) combo ports
  • Type: Gigabit Ethernet
  • Ports: 24
  • Data Transfer Rate: 1Gbps
  • Managed: Yes
  • POE: No
Product codes
NETGEAR’s family of reliable, high-performance ProSAFE Gigabit Layer 3 Stackable Switches provides maximum throughput and flexibility for demanding networks, with all the Layer 3 features you expect— and the future proofing you want. The ProSAFE GSM7328S, GSM7328FS or GSM7352S are ideal as a backbone switches, Gigabit servers, or as the robust core of a demanding, all-Gigabit network. These ProSAFE Gigabit switches can be used to inexpensively off-load routers that are segmenting your network and lay the groundwork for new IP-based services. All three switches include four hot-swappable, high-speed module bays which offer options for standards-based10G connectivity or for 48Gbps stacking within the switch family. For maximum flexibility, the GSM7328S and GSM7352S offer 24 and 48 Copper Gigabit Ports, respectively, while the GSM7328FS offers 24 SFP slots for high-density fiber deployments. The non-blocking design of the switch delivers simultaneous, full wire-speed, low-latency throughput to all ports.
Product Description Netgear Next-Gen Edge Managed Switch M5300-28GF3 - switch - 24 ports - Managed
Device Type Switch - 24 ports - L3 - Managed - stackable
Enclosure Type 1U
Subtype Gigabit Ethernet
Ports 24 x Gigabit SFP + 4 x shared 10/100/1000
Performance Switching capacity: 144 Gbps , Throughput: 107.1 Mbps
Capacity 224 , IP router interfaces: 128
MAC Address Table Size 8K entries
Jumbo Frame Support 9000 bytes
Routing Protocol OSPF, RIP-1, RIP-2, BGP, IGMPv2, IGMP, VRRP, OSPFv2, PIM-SM, PIM-DM, IGMPv3, OSPFv3
Remote Management Protocol SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, TFTP, CLI
Features Layer 3 switching, BOOTP support, ARP support, VLAN support, IGMP snooping, traffic shaping, DiffServ support, Weighted Round Robin (WRR) queuing, store and forward, IPv6 support, sFlow, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Quality of Service (QoS), DHCP server, MLD snooping, IPv4 support, DHCP relay, Link Aggregation Control Protocol (LACP), Dynamic VLAN Support (GVRP), Class of Service (CoS)
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1v, IEEE 802.1ab (LLDP)
Power AC 120/230 V (50/60 Hz)
Dimensions (WxDxH) 44 cm x 39.1 cm x 4.3 cm
Weight 6.3 kg
Manufacturer Warranty NETGEAR lifetime warranty
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£1,500.69
Notify me
