We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Get fast speeds with the NETGEAR AC1900 Wi-Fi Nighthawk VDSL/ADSL modem router. Enjoy the ultimate in Wi-Fi speeds up to 1.9Gbps and a powerful dual core 1GHz processor for extreme performance. High-powered amplifiers, external antennas and Beamforming+ improve range and reliability. Nighthawk supports ADSL/ADSL2/ADSL2+ and VDSL/VDSL2.
Product Description | NETGEAR Nighthawk - wireless router - DSL modem - 802.11a/b/g/n/ac - desktop | Device Type | Wireless router - DSL modem - 4-port switch (integrated) | Enclosure Type | Desktop | Digital Signaling Protocol | ADSL, VDSL, ADSL2, ADSL2+, VDSL2 | WAN Ports Qty | 1 | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Frequency Band | 2.4 GHz / 5 GHz | Data Transfer Rate | 1900 Mbps | Network / Transport Protocol | FTP | Features | Firewall protection, auto-sensing per device, NAT support, VPN support, Stateful Packet Inspection (SPI), DoS attack prevention, IPv6 support, parental control, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), Wireless Guest Services, FTP server, ReadySHARE, Push ‘N’ Connect button, 3T3R MIMO technology, Beamforming+ | Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Dimensions (WxDxH) | 28.5 cm x 18.5 cm x 5 cm | Weight | 750 g | System Requirements | UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7/8/8.1 | Localisation | United Kingdom | Manufacturer Warranty | 1-year warranty |
General | |
Device Type | Wireless router - 4-port switch (integrated) |
Connectivity Technology | Wireless, wired |
Encryption Algorithm | WPA-PSK, WPA2-PSK |
Processor | 1 GHz |
RAM | 256 MB |
Flash Memory | 128 MB |
Line Properties | |
Line Coding Format | 256 QAM |
Communications | |
Type | DSL modem |
Expansion / Connectivity | |
Interfaces | LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 2 x 9 pin USB Type A , Phone line: 1 x VDSL2 / ADSL2+ - RJ-11 |
Aerial | |
Aerial | External detachable |
Antenna Qty | 3 |
Power | |
Power Device | External power adapter |
Miscellaneous | |
Included Accessories | POTS filter |
Cables Included | 1 x network cable , 1 x phone cable |
Software / System Requirements | |
OS Required | UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7/8/8.1 |
Dimensions & Weight | |
Width | 28.5 cm |
Depth | 18.5 cm |
Height | 5 cm |
Weight | 750 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
