Nighthawk Tri-Band AX12 RAX200 WiFi Router is powered by the industry's latest WiFi 6 (802.11ax) standard with 4 times increased data capacities to handle more devices on your network. Blazing-fast combined WiFi speeds up to 10.8Gbps and AX optimized 1.8GHz quad-core processor powers smart home applications, multiple 4K/8K streaming, low latency gaming, and more.
Product Description | NETGEAR Nighthawk RAX200 - wireless router - 802.11a/b/g/n/ac/ax | Device Type | Wireless router - 5-port switch (integrated) | WAN Ports Qty | 1 | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, 2.5 Gigabit Ethernet, 802.11ax | Frequency Band | 2.4 GHz (1 band) / 5 GHz (2 bands) | Capacity | Streams: 12 | Intelligent Assistant | Google Assistant, Alexa | Features | VPN support, firmware upgradable, reset button, Beamforming+, MU-MIMO technology, Link Aggregation, LED on/off button, guest access, Circle Smart Parental Controls | Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11i, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax, Wi-Fi CERTIFIED 6 | Dimensions (WxDxH) | 29.5 cm x 22.7 cm x 5.44 cm | Weight | 1.1 kg | System Requirements | UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7/8/10 | Localisation | Europe | Manufacturer Warranty | 1-year warranty |
General | |
Connectivity Technology | Wireless, wired |
Encryption Algorithm | 128-bit AES |
Wi-Fi Rating | AX11000 |
Processor | 1.8 GHz |
Line Properties | |
Line Coding Format | 256 QAM, 1024 QAM, OFDMA |
Internet of Things (IoT) | |
Expansion / Connectivity | |
Interfaces | LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 1 x 1G/2.5G Multi-Gig Ethernet - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 2 x 9 pin USB Type A |
Aerial | |
Aerial | Internal |
Antenna Qty | 8 |
Power | |
Power Device | External power adapter |
Miscellaneous | |
Cables Included | 1 x network cable |
Software / System Requirements | |
OS Provided | No operating system |
OS Required | UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7/8/10 |
Dimensions & Weight | |
Width | 29.5 cm |
Depth | 22.7 cm |
Height | 5.44 cm |
Weight | 1.1 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year , Limited warranty - technical support - 90 days |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
