The NETGEAR 4-Stream AX1800 Wi-Fi 6 Router upgrades your network to provide greater capacity with consistent and powerful signal strength to all your connected devices. Powerful quad-core 1.5GHz processor ensures superior performance for concurrent realtime applications such as multimedia streaming, online gaming and audio/video chats.
Product Description | NETGEAR RAX10 - wireless router - 802.11a/b/g/n/ac/ax - desktop | Device Type | Wireless router - 4-port switch (integrated) | Enclosure Type | Desktop | WAN Ports Qty | 1 | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, 802.11ax | Frequency Band | 2.4 GHz / 5 GHz | Capacity | Streams: 4 | Intelligent Assistant | Google Assistant, Alexa | Features | VPN support, firmware upgradable, reset button, guest access, NETGEAR Armor, Voice Control, 4K UHD video streaming | Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11i, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax, Wi-Fi CERTIFIED 6 | Dimensions (WxDxH) | 23.6 cm x 18.4 cm x 5.7 cm | Weight | 500 g | System Requirements | UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7/8/10 | Localisation | Europe | Manufacturer Warranty | 1-year warranty |
General | |
Connectivity Technology | Wireless, wired |
Encryption Algorithm | 128-bit AES, WPA3 |
Wi-Fi Rating | AX1800 |
Processor | 1.5 GHz |
RAM | 512 MB |
Flash Memory | 256 MB |
Line Properties | |
Line Coding Format | 256 QAM, 1024 QAM |
Internet of Things (IoT) | |
Expansion / Connectivity | |
Interfaces | LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 |
Aerial | |
Aerial | External |
Antenna Qty | 4 |
Power | |
Power Device | External power adapter |
Miscellaneous | |
Cables Included | 1 x network cable |
Software / System Requirements | |
OS Provided | No operating system |
OS Required | UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7/8/10 |
Dimensions & Weight | |
Width | 23.6 cm |
Depth | 18.4 cm |
Height | 5.7 cm |
Weight | 500 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year , Technical support - 90 days |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
