8 Wi-Fi streams offer four times the device capacity that typical 2x2 AC Wi-Fi does. More Wi-Fi streams more bandwidth availability and less congestion. Now, more devices than ever before can reliably and simultaneously connect to your network.
Product Description | NETGEAR RAX70 - wireless router - 802.11a/b/g/n/ac/ax - desktop | Device Type | Wireless router - 4-port switch (integrated) | Enclosure Type | Desktop | WAN Ports Qty | 1 | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, 802.11ax | Frequency Band | 2.4 GHz (1 band) / 5 GHz (2 bands) | Capacity | Streams: 8 | Network / Transport Protocol | IPv6 | Features | NAT support, VPN support, DFS support, firmware upgradable, reset button, Beamforming+, MU-MIMO technology, Dynamic QoS, 4K UHD video streaming, 160MHz bandwidth support | Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11i, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax, Wi-Fi CERTIFIED 6 | Dimensions (WxDxH) | 34.7 cm x 20.8 cm x 16.5 cm | Weight | 1.171 kg | Localisation | Europe | Manufacturer Warranty | 1-year warranty |
General | |
Connectivity Technology | Wireless, wired |
Encryption Algorithm | WPA-PSK, 128-bit AES, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise |
Wi-Fi Rating | AX6600 |
Processor | 1.5 GHz |
RAM | 512 MB |
Flash Memory | 256 MB |
Status Indicators | Status |
Line Properties | |
Line Coding Format | 256 QAM, 1024 QAM, OFDMA |
Expansion / Connectivity | |
Interfaces | WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x 9 pin USB Type A |
Miscellaneous | |
Dimensions & Weight | |
Width | 34.7 cm |
Depth | 20.8 cm |
Height | 16.5 cm |
Weight | 1.171 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year , Technical support - 90 days |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
