The NETGEAR Nighthawk AX8 8-Stream Mesh Extender (EAX80) supports the latest generation WiFi 6 (802.11ax) standard. This powerful Nighthawk Mesh Extender works with your existing WiFi to create a powerful whole home mesh WiFi system. Enjoy a better connected home experience and extend faster WiFi to the farthest corners of your home with blazing fast speeds up to 6 Gbps.WiFi.
Product Description | NETGEAR Nighthawk AX8 EAX80 - Wi-Fi range extender - Wi-Fi 6 | Device Type | Wi-Fi range extender | Form Factor | External | Processor | 1.8 GHz | Ports Qty | 4 | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, 802.11ax | Frequency Band | 2.4 GHz, 5 GHz | Dimensions (WxDxH) | 27.9 cm x 19.7 cm x 10.6 cm | Weight | 860 g | Manufacturer Warranty | 1-year warranty |
General | |
Width | 27.9 cm |
Depth | 19.7 cm |
Height | 10.6 cm |
Weight | 860 g |
Processor / Memory / Storage | |
Processors Installed | 1.8 GHz |
Networking | |
Ports Qty | 4 |
Connectivity Technology | Wireless |
Line Coding Format | 256 QAM, 1024 QAM |
Network / Transport Protocol | IPv6 |
Remote Management Protocol | IPv6 |
Wi-Fi Rating | AX6000 |
Features | Auto-sensing per device, Mesh networking, ReadySHARE, reset button, Beamforming+, Smart Connect, 4x4 MU-MIMO technology, Smart Roaming, Orthogonal Frequency Division Multiple Access (OFDMA), 4K HD video streaming, 8K HD video streaming |
Encryption Algorithm | 128-bit AES |
Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11i, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11ax, Wi-Fi CERTIFIED 6 |
Aerial | |
Antenna | Internal |
Antenna Qty | 4 |
Expansion / Connectivity | |
Interfaces | 4 x 1000Base-T - RJ-45 , 1 x USB 3.0 - Type A |
Power | |
Power Device | External power adapter |
Software / System Requirements | |
OS Provided | No operating system |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
