We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
NETGEAR Nighthawk Pro Gaming brings versatile and limitless gaming with SX10 8-port Switch with 2x 10G/Multi-Gig Uplinks. Get close to zero latency, precision driven auto-diagnostics and a new gaming dashboard. Its sleek design and one-click configurations will impress your fellow gamers at LAN parties. Unleash your speeds potential.
Product Description | NETGEAR Plus SX10 - switch - 8 ports | Device Type | Switch - 8 ports | Subtype | Gigabit Ethernet | Ports | 8 x 1000Base-T + 2 x 100/1000/2.5G/5G/10G (uplink) | Performance | Bandwidth: 56 Gbps , Forwarding performance (64-byte packet size): 41.664 Mfps | Capacity | Priority queues: 8 , IGMP multicast groups: 128 | MAC Address Table Size | 16K entries | Routing Protocol | IGMPv2, IGMP, IGMPv3 | Remote Management Protocol | HTTP | Features | Flow control, IGMP snooping, port mirroring, store and forward, firmware upgradable, Quality of Service (QoS), Link Aggregation Control Protocol (LACP), DHCP client, Energy Efficient Ethernet, 2MB packet buffer, 4K resolution support, Class of Service (CoS), DiffServ Code Point (DSCP) support, administrator's password, LED on/off button, Weighted Round Robin (WRR), VLAN Tagging | Compliant Standards | IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3an, IEEE 802.3az, IEEE 802.3bz | Dimensions (WxDxH) | 26.8 cm x 20.3 cm x 9.3 cm | Weight | 1.515 kg | Localisation | United Kingdom | Manufacturer Warranty | 3-year warranty |
General | |
Enclosure Type | Desktop |
Status Indicators | Status |
Expansion / Connectivity | |
Interfaces | 8 x 1000Base-T RJ-45 , 2 x 100/1000/2.5G/5G/10GBase-T RJ-45 uplink |
Power | |
Power Device | External power adapter |
Power Consumption Operational | 14.19 Watt |
Miscellaneous | |
Compliant Standards | CB, LVD, EAC |
Dimensions & Weight | |
Width | 26.8 cm |
Depth | 20.3 cm |
Height | 9.3 cm |
Weight | 1.515 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 90% (non-condensing) |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Humidity Range Storage | 95% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
