We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Marketing description is not available.
Product Description | NETGEAR Orbi WiFi System RBK53 - Wi-Fi system - 802.11a/b/g/n/ac - desktop | Device Type | Wi-Fi system - mesh | Enclosure Type | Desktop | Wi-Fi System Components | Router, 2 extenders | Wi-Fi System Coverage | Up to 7,500 sq.ft | WAN Ports Qty | 1 | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Frequency Band | 2.4 GHz (1 band) / 5 GHz (2 bands) / 5 GHz (3 bands) | Intelligent Assistant | Alexa | Features | MU-MIMO technology, beamforming technology, guest access, Circle Smart Parental Controls | Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Dimensions (WxDxH) | 16.3 cm x 7.87 cm x 20.3 cm | Weight | 889 g |
General | |
Device Type | Wi-Fi system - mesh - 3-port switch (integrated) |
Connectivity Technology | Wireless, wired |
Encryption Algorithm | WPA2-PSK |
Wi-Fi Rating | AC3000 |
Mesh Networking | Yes |
RAM | 512 MB |
Flash Memory | 4 GB |
Line Properties | |
Line Coding Format | 256 QAM |
Internet of Things (IoT) | |
Expansion / Connectivity | |
Interfaces | WAN: 1 x 1000Base-T - RJ-45 , LAN: 3 x 1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A |
Aerial | |
Aerial | Internal |
Power | |
Power Device | External power adapter |
Miscellaneous | |
Cables Included | 1 x network cable - 2 m |
Dimensions & Weight | |
Width | 16.3 cm |
Depth | 7.87 cm |
Height | 20.3 cm |
Weight | 889 g |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
