We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
This sleek and elegant Orbi Pro Ceiling Add-on Satellite expands your Orbi Pro Wi-Fi System coverage by up to 2,500 square feet with high-performance AC3000 Wi-Fi.
Product Description | NETGEAR Orbi Pro Ceiling Add-on Satellite (SRC60) - Wi-Fi range extender - Wi-Fi 5 | Device Type | Wi-Fi range extender | Form Factor | Wall / ceiling mountable | Localisation | Europe | Ports Qty | 2 | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Frequency Band | 2.4 GHz (1 band) / 5 GHz (2 bands) | Included Accessories | Wall mounting kit, ceiling mounting kit | Dimensions (WxDxH) | 26.715 cm x 23.859 cm x 4.072 cm | Weight | 863 g |
General | |
Width | 26.715 cm |
Depth | 23.859 cm |
Height | 4.072 cm |
Weight | 863 g |
Networking | |
Ports Qty | 2 |
Connectivity Technology | Wireless |
Line Coding Format | 256 QAM |
Max Coverage Area | Up to 2,500 sq.ft |
Wi-Fi Rating | AC3000 |
Features | MU-MIMO technology, guest access, FastLane3 technology, Explicit Beamforming, Implicit Beamforming |
Encryption Algorithm | WPA, WPA2-PSK |
Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac |
Aerial | |
Antenna | Internal |
Antenna Qty | 6 |
Expansion / Connectivity | |
Interfaces | 1 x 1000Base-T (PoE) - RJ-45 , 1 x 1000Base-T - RJ-45 |
Miscellaneous | |
Power | |
Power Device | External power adapter |
Installed Qty | 1 |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
